Taco E locker in 1985
Old Dec 2, 2014 | 07:54 AM
dlbarb's Avatar
So I found a really good deal on a complete rear end with an e-locker from a wrecked truck. I actually can get the 5 speed trans&xfer case drive shafts and all the front end drive components as well which I pan to sell to a friend with a prerunner. I also have the switch for the elocker. I am thinking of keeping the trans and the rear to install in my truck. The trans will be utilized when I upgrade to a 4.3 LV3 or ls1 next gen v6. My question for the immediate short term is what is the best way to go about the rearend swap. I assume a complete swap is the easiest way to do this since the 3rd wont fit in my housing correct? The next question is on the wiring. I assume a simple fused relay circuit will suffice?
Old Dec 2, 2014 | 07:59 AM
JasonYota's Avatar
There is plenty of info out on this. I would swap the entire axle since you have it.
Old Dec 2, 2014 | 09:35 AM
dlbarb's Avatar
Well I have tried sever searches in this forum but found very little. I am sure my search criteria is wrong. If anyone has a link I would appreciate it.
Old Dec 2, 2014 | 09:41 AM
JasonYota's Avatar
Try "elocker retrofit" that should come up plenty
Old Dec 7, 2014 | 06:51 PM
Oatmeal's Avatar
The Tacoma axle is quite a bit wider than yours (your front too).
Modifying your housing isn't that difficult nor is building a controller.
I run one in my front axle.
Here's a good write up: http://www.4x4wire.com/toyota/tech/electric_locker/
Hans
Old Dec 8, 2014 | 04:39 AM
dlbarb's Avatar
Great info Thanks for the reply!!
TheBFA
Feb 15, 2020 06:55 AM
Iceman4193
Oct 16, 2015 10:50 AM
1985 4Runner
Sep 30, 2015 10:17 AM
rmill05
Sep 27, 2015 01:43 PM
Toys4parts
Sep 26, 2015 01:56 PM
