A.T. Oil Temp, Charge, and Brake light come on every once in a while when driving.
Old Dec 13, 2024 | 10:52 AM
niko0420's Avatar
I’ve been having this problem that has only happened once before and happened again today. all three lights came on in my truck and nothing happened but they stayed on for a while and kind of felt like I had a slight loss of power but don’t really know? Anyone if you know the solution to my problem. Much appreciated
Old Dec 13, 2024 | 01:27 PM
millball's Avatar
Alternator hiccup??
Check the alternator brushes for wear.
Old Dec 13, 2024 | 01:34 PM
niko0420's Avatar
Alternator hiccup??
Check the alternator brushes for wear.[/QUOTE]
Im still pretty much a noob to the whole mechanical side of cars since I am really young with an 85 runner, but besides that where would I check the brushes?
Old Dec 13, 2024 | 01:39 PM
millball's Avatar
The brush cassette is a replaceable internal part of the alternator.
Wear there is often the cause of alternator failure and sometimes first shows as an intermittent no charge condition.
That wear part can be replaced for 20 dollars or so,
A substantial savings over the purchase of another alternator.
Old Dec 13, 2024 | 03:33 PM
niko0420's Avatar
A substantial savings over the purchase of another alternator.[/QUOTE]
Your talking about the brush pack in the alternator correct? I just did a little bit of research on it.
Old Dec 13, 2024 | 03:37 PM
millball's Avatar
Brushes inside the alternator. Yes
Old Dec 13, 2024 | 03:39 PM
niko0420's Avatar
Brushes inside the alternator. Yes[/QUOTE]
Ok for sure appreciate the info! I will try and order the genuine brushes and hopefully that will help my problem. I only have 173k miles on the truck so hopefully it’s not the alternator
Old Jan 8, 2025 | 01:03 PM
Damion812's Avatar
5 Year Member
Usually this is a sign of the regulator going out and overcharging. Whatever you do keep the original alternator and rebuild it. New brushes while there is a good idea too. It's easy.
Old Jul 2, 2025 | 11:25 PM
niko0420's Avatar
Replaced alternator
Well I tried to have my dad’s mechanic replace the brushes and he said to take my alternator in for core charge as my alternator I had was also a cheap autozone or oreily alternator but I needed the truck for school at the time and just got it done. Now fast forward multiple months later the truck has started to freak out even more by constantly flashing the 3 lights and they stay on. The truck started to smell a little funny like make the alternator pully was going and starting to fail and I heard somewhat of a whirring noise, so I decided to head home and parked it. Any ideas please fellow yota wizards I love this truck and want it to be fixed already.
Old Jul 3, 2025 | 11:20 AM
Discombobulated's Avatar
I would get the alternator checked, the failure rate for aftermarket parts is poo, especially for alternators….was the smell a burning rubber/belt smell or electrical??
Old Jul 3, 2025 | 11:37 AM
niko0420's Avatar
Im not too sure, I know I dont have any other leaks on the truck so Im thinking maybe it was rubber burning smell since the truck started to kinda make a new whirring noise im thinking it’s the alternator pulley going out like it did on the last alternator and from what I remember somewhat smells the same. I dont really remember as I panicked to get home lmao.
Old Jul 6, 2025 | 11:35 AM
Damion812's Avatar
5 Year Member
this☝️
New starters are garbage too. I've had them fail right out of the box.
Old Jul 6, 2025 | 11:42 AM
niko0420's Avatar
this☝️
New starters are garbage too. I've had them fail right out of the box.[/QUOTE]
But would starters throw those lights? I thought only alternator throws those lights
Old Jul 6, 2025 | 11:56 AM
OldBlueMidnight's Avatar
5 Year Member
I don't know about the AT temp light, but the brake and charge lights will come on intermittently when the battery cable in my 85 is loose. Last time there was a bit of crud stuck between the terminal and the battery post, so it really seemed tight.
Old Jul 6, 2025 | 02:09 PM
niko0420's Avatar
I do have a little bit of the white corrosion stuff on my battery terminal but not enough to where I think it would affect anything
Old Jul 6, 2025 | 05:22 PM
Damion812's Avatar
5 Year Member
Originally Posted by niko0420
this☝️
But would starters throw those lights? I thought only alternator throws those lights[/QUOTE]
no no I was just saying like the alternator they are a crap shoot these days. I think it's your alternator again.
Old Jul 6, 2025 | 06:51 PM
niko0420's Avatar
no no I was just saying like the alternator they are a crap shoot these days. I think it's your alternator again.[/QUOTE]
Yeah im hoping it is so I can just go to oreilys and return it and buy one oem used and send it out to get rebuilt.
Old Jul 21, 2025 | 07:41 AM
Did you get this sorted??
Old Jul 21, 2025 | 01:08 PM
niko0420's Avatar
I haven’t thoroughly took the time to look at it since I’ve had a pretty busy summer so far but I should be getting some free time soon to check it out. It’s also because I dont really work on my truck especially with the pulleys and stuff because I dont know torque specs and where to start by pulling off the alternator lol.
popthree
May 29, 2013 04:48 PM
jagermeister
May 27, 2009 09:11 PM
4everunner
Sep 30, 2007 01:07 PM
mattk
Aug 7, 2007 10:21 AM
phatdawg
Nov 30, 2005 05:26 PM
