T-case Gasket
Old Jul 25, 2007 | 06:16 PM
85yotalover's Avatar
T-case Gasket
I seperated my t-case from my tranny because the bearing was burnt. The large gasket shattered on the way out. I was thinking about using high temperature rtv sealant. The gasket was very large, it seems like it had some sort of purpose like redirecting oil flow. I was told to use rtv and it would be fine but i want a second opinion, as i have only 1 more good t-case. Any help is appreciated, thanks.
Old Jul 25, 2007 | 06:37 PM
MudHippy's Avatar
I've used RTV for that seal a few times, works fine. There's no reason for there to be oil in that space between the t-case and transmission. If there was when you opened it, that tells you there's a bad seal. Rear transmission output, or front transfer case input seal or both.
Old Jul 26, 2007 | 06:23 AM
Volcom's Avatar
http://board.marlincrawler.com/index.php?topic=34910
Rowdydudeman
Nov 26, 2015 02:17 PM
priest16
15
Aug 6, 2015 07:43 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
scottyg486
Jul 19, 2015 05:34 PM
89hilux1
Jul 19, 2015 01:32 AM
