Stock front axle shaft spline wear
Old Jan 4, 2012 | 08:40 AM
sorensenjg's Avatar
So i pulled my driver side axle shaft last night while working on a knuckle rebuild. This is what the inner spline looked like. Should i be concerned? What do you think the wear pattern indicates? It has 4.88's and a detroit up front.
Notice the wear pattern?
Old Jan 4, 2012 | 08:50 AM
waskillywabbit's Avatar
Is it worn in those dimple spots or just stained?
:wabbit2:
Old Jan 4, 2012 | 09:22 AM
sorensenjg's Avatar
:wabbit2:
Its just stained, it feels smooth to the touch
Old Jan 4, 2012 | 09:50 AM
scuba's Avatar
Probably just had some water in the diff at one point. I wouldn't worry about it.
Old Jan 4, 2012 | 09:59 AM
sorensenjg's Avatar
I suppose that is a valid option. However doesnt it seem weird that the "stains" or "wear" are almost perfectly spaced out?
Old Jan 4, 2012 | 01:08 PM
sorensenjg's Avatar
any other ideas?
Old Jan 28, 2012 | 07:24 PM
mommucked's Avatar
Maybe it's from the locker ingageing and releasing and shifting in the slight gap in the male/female splines? It looks like it's not worn much or deformed.
Old Jan 31, 2012 | 07:11 AM
sorensenjg's Avatar
thanks for the replys, its not bad by any means, just curious. im going to let it ride.
Old Feb 1, 2012 | 10:44 AM
peow130's Avatar
The machining on the splines on the inside of the diff might have done that. Nothing you need to worry about.
if you wanna see some spline wear i have a 60 year old front driveshaft out of a willy's jeep with some serious spline wear lol
kazuya2416
Apr 5, 2024 02:17 AM
lledwod
Aug 30, 2016 01:03 PM
jerusry
Oct 19, 2015 05:28 PM
ItsJustD
Jul 7, 2015 07:49 AM
toyoda8488
Jul 5, 2015 10:18 PM
