Sr5 Cluster Swap
Old Jul 23, 2009 | 11:52 AM
Ultimate's Avatar
Sr5 Cluster Swap
I just picked up a cluster from a v6 1st generation 4runner. My question is about the oil pressure sender. Do I need to get an oil pressure sender from a v6 or from a 4cyl. Also, I read the tachometer may be off a bit. Can I fix this?
Old Jul 23, 2009 | 09:01 PM
myyota's Avatar
No, the sending unit doesn`t need to be from a V6, just get one for a SR5 22RE, but if you put the new cluster in before you change the oil sending unit unplug the sending unit on your engine first, otherwise you will fry the oil presure gauge. The tachometer will be off a little, and i know it can be corrected, but im not sure how to do it, try doing a search because i know its been posted here before how to do it.
Flying91
45
Apr 11, 2024 04:39 PM
gary4runner
Sep 24, 2015 12:53 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
Esibnitsud
Jul 30, 2015 08:21 PM
Rkellerman
Jul 12, 2015 08:42 AM
