SR-5 fender edge trim (need to remove)
Old Jan 7, 2015 | 07:16 PM
Whitfield's Avatar
I was able to get a few hours work in. 3 hrs yesterday on the lower patch and 4 hrs today on the upper. Working outside temps right at freezing and a 8-12 mph wind (not good for gas shield mig welding).
Old Jan 7, 2015 | 07:25 PM
Whitfield's Avatar
Upper patch fitted into cut out. This is the most time consuming part. A good friend who does production work says he cuts his patches with a Plazma cutter. Place the patch over the hole and cut both the patch and panel at the same time / same cut. I'm stuck using tin snips and a hand file ~ but it works.
splurged and bought (2) cans of primer. 1 SEM self etching and one Upol weld through. $52.16 OUCH. Not sure they are worth it but I figured I'd give them a try. Just needs to warm up a bit / temps below freezing next few days.
Next up is drivers side front of bed.... Ugggh
Old Feb 15, 2015 | 05:43 PM
Whitfield's Avatar
My 1985 HiLux truck was incomplete / not for sale.... I had only put 380 miles on it.
That did not stop a guy from knocking on my door and throwing money at me until I said yes. . . Still sad about it.
I had to buy a Tacoma to ease the pain. 1996 X-cab 4wd auto 6" suspension lift = 33's
Previous owner had terminal ball joint failure. Partially repaired (failed new hub bearing install / new lower ball joint welded onto bad left knuckle).
Old Feb 16, 2015 | 05:15 PM
Nervo19's Avatar
[QUOTE=Whitfield;52255077].
"My 1985 HiLux truck was incomplete / not for sale.... I had only put 380 miles on it.
That did not stop a guy from knocking on my door and throwing money at me until I said yes. . . Still sad about it."
So you've sold the gray ex cab? I thought it was an '84.
You've done the best thread of cutting donor panels and welding them. I've not seen better on the Toyota sites I read.
I finally matched my son's money and got something with air bags. A one owner 2000 Ex Cab with the TRD option. The picture showed up at the top of my post.
4x4-runner
Apr 18, 2017 09:08 PM
nonstop
7
Aug 11, 2015 09:26 AM
Flossy
Aug 5, 2015 05:14 PM
skebe22RTE
Jul 31, 2015 02:03 PM
