Squeaky seat is driving me nuts
Old Mar 22, 2007 | 02:54 AM
paxil4x4's Avatar
Drama Queen/Banned
My bench seat is get really squeaky, It to the point where it is pissing me off to the point I want to install a bean bag to sit on. All the bolts are tight, all the rubber bumpers look good. What is making the noise.
The whole truck is sound matted inside.
Old Mar 22, 2007 | 10:13 PM
the_supernerd's Avatar
Mine squeaks sometimes from the lever that keeps the back latched. Make sure it is latched tight. If it will not latch tight, maybe put something back there that will keep it tight. If that is not it, then take the seat out and put a little WD-40 on anything that could squeak.
Old Mar 23, 2007 | 06:19 PM
BeaterToyota's Avatar
It's probably the internal (or underneath) steel springs squeaking. If a spring is squeaky there's no way to quiet it. Think about an old mattress/box spring.
My clutch pedal return spring squeaks like crazy, but I only drive the beater a couple times a month so I just deal with it.
Old Mar 23, 2007 | 11:52 PM
paxil4x4's Avatar
Drama Queen/Banned
I should just look for some used Recaros and toss the bench.
Old Mar 24, 2007 | 07:39 PM
trousertrout's Avatar
I put some bearing grease on the springs on mine and it kinda went away. I had to cake it on, but it helped out a lot. I eventually replaced mine with some bucket seats though . . .
Old Mar 25, 2007 | 12:00 PM
Just Learning's Avatar
paxil- check this out- i thought my bench were sqeaking also but it was coming from my seat belt im not kidding i get in put the belt on drive off and have this squeaking sound, i stop move around on the seat-squeak get out push on the seat nothing- anyway thats what it was- just something to maybe consider
Old Mar 25, 2007 | 01:37 PM
isaac338's Avatar
swap in some sr5 buckets and be done with it. who wants bench seats anyways?
Old Mar 29, 2007 | 08:44 PM
Fahrenheit 451's Avatar
If it is like the 4Runner, there will be a piece mounted to the floor pan the seat bolts to that can break loose over the years.
A complete WAG, but pull up the trim piece on the door sill and the floor covering to check and see if the spot welds holding that piece in place have broken loose. There isn't much holding them in as scary as that sounds.
Like I said, a total guess, but it is something that happens on 4Runners from that same period.
Old Mar 29, 2007 | 11:00 PM
paxil4x4's Avatar
Drama Queen/Banned
I found out the seat tracks are worn-out. So I took a small wooden door shims and hammered them in between the tracks so no more noise.
I feel guilty, because this is the first time of done something so for a repair.
I plan to toss the seats and buy some Recaros at a later date. The only way I would take SR5 seats is if they were free.
Whatever123
Sep 30, 2015 12:12 AM
redneck17
Jul 17, 2015 07:44 PM
Cdn-wilderness
Jul 10, 2015 07:43 PM
icentropy
Jul 9, 2015 02:12 PM
garagespace
Jul 9, 2015 08:37 AM
