Sputtering 22r. Trans, Fuel, Timing? Help
I have a 84 22r and can not figure out what is causing the the truck to sputter intermittently. When diving at say 45 or 55 in 4th or 5th gear up an hill, the truck sputters and jerks. When I drop to a lower gear it works fine most of the time. When step on the clutch the engine idles fine. I replace all of the vaccum lines, tested the vaccum advance (works fine) and raise the fuel level. I replace the fuel pump, tank, filter, coil, plugs, wires, dist cap & rotor. The only thing I noticed is the clutch MC losses fluid, could a clutch probelm be causing this? If not what about a clogged EGR?
Jun 1, 2021 01:51 PM
Jnkml
Jul 6, 2015 01:20 PM
22r, 22re, 84, advance, enginge, forum, llc, pickup, sale, sputter, sputtering, timing, toyota, transfueler, transfuels
