so i got a death wobble?
ya im getting a death wobble at about 50mph but its not always there,but sometimes it is. my dad says it is the u joints in the rear driveshaft( i have a 2 piece driveshaft).
so is he right anyones input is welcome.
also it sometimes pulls to the left but not always.
thanks for any help.
Travis
so is he right anyones input is welcome. also it sometimes pulls to the left but not always.
Travis
Death Wobble can be attribute to many things especially on an SA.
Out of balance/worn tires
Bent Tie Rods
Bad wheel bearings
Broken Spring
Bent Frame
those are just off the top of my head
I would recommend jacking up your truck and moving your wheels by hand and check for any excessive play. When I had the "death wobble' on my old '84 it was due to lack of maintenance on my part from water crossing and not greasing the wheel bearings...rebuilt the front end, and it fixed it. Good luck, tracking them down can be a headache.
No disrespect to your dad, but I am not sure how a rear drive shaft issue would make your truck pull to the left (assuming DW is upfront) you may need to replace your rear u joints too...old trucks are just that, old and need maintenance.
Bent Tie Rods
Bad wheel bearings
Broken Spring
Bent Frame
I agree with you ocdropzone i couldnt figure out why the u joints would do that either also i checked them and they seem to be good.im thinking its Bent Tie Rods, Bad wheel bearings, or Broken Spring. when i get home today ill do a little check up on it, and see if i can figure it out. thanks for your input, if anyone else has any feel free to add it.
check your steering components, and wheel bearings, as stated.
Death wobble is a function of manual steering.
If those other things don't fix it, its your caster. Get it checked, and cut and weld the perches to fix.
Best and cheapest way I've found to combat DW, Hydro Assist!!! Worked like a charm on mine
Mine death wobbled with all brand new stuff after my 4" lift. It was a combo of my completely worn out tires and caster. I don't think you can cut off the perches and reweld. You have to cut and turn the balls.
death wobble is usually in the front....not the rear...
If the vibration is coming from the rear its most likely your driveshaft.
Check to make sure you havent lost any weights on the shaft.
Also, check to make sure that your u-joints are greased and in good condition.
Also, check to make sure your u-joints are in-phase
I would recommend using OEM toyota wheel bearings (Koyo) they are more expensive but worth it. There are some good writeup on the intardweb on the proper procedure for setting the bearings
potatopants
Sep 15, 2015 06:26 AM
lfcarrion3
Jul 18, 2015 04:05 PM
