Seized leaf spring bolts
Old Aug 17, 2020 | 02:27 PM
donepham's Avatar
I’m in the process of doing a rc 3in lift on my 85 pickup and I’m having issues with seized bolts because of the very old bushings in the springs. Anyone got any ideas?
Old Aug 19, 2020 | 12:43 PM
2ToyGuy's Avatar
Lots of penetrating oil, wait a few hours for it to work it's way down the threads, rinse, repeat.
After a few cycles of that, hit it with heat, either a cutting torch, or a MAP gas set up, then apply, judiciously, a BFH to it.
Repat all of the above until they break loose. An impact driver, with a heavy, 6 point, impact socket to fit, is also very helpful, either after the whole penetrating oil series, or on it's own.
I wish you good fortune! Seized bolts can be rough...
Pat☺
Old Aug 20, 2020 | 05:43 AM
se7enine's Avatar
Just be careful banging around under their with a BFH and the jack stands at max like they look.
Old Aug 24, 2020 | 01:30 PM
welder7018's Avatar
torch them off
Old Aug 27, 2020 | 06:26 PM
donepham's Avatar
Yeah trying not to use a bfh cause I don’t want to damage the bolts. Hard to find shackles and pins for this thing. Instead I bout a bf pry bar. That and A LOT of heat is working. Very slow process. I appreciate the help.
have anyone you done this lift or now anything about it? Im curious about running the shims that come with it.
Old Aug 29, 2020 | 08:08 PM
moto809's Avatar
5 Year Member
I've had to literally burn the bushings out with an acetylene torch on older trucks before. Not fun, but gets it done. Get a respirator if you go that route.
Old Sep 6, 2020 | 05:28 PM
thefishguy77's Avatar
I used a cutoff wheel to get one of mine free.
Old Sep 27, 2020 | 02:47 PM
ratas calientes's Avatar
Did you finally get them out?
Old Sep 27, 2020 | 07:14 PM
donepham's Avatar
yeah i was able to pull them with A LOT of heat and a BF pry bar with blood sweat and tears. I bent one of them with a bfh and was lucky enough to find some new ones at the dealership.
Krog321
Mar 27, 2016 02:18 PM
Little Elger
Dec 5, 2012 05:44 AM
4Runner1986
Jun 24, 2011 04:45 AM
Turbo4Runner
Dec 21, 2007 07:27 PM
ianshoots
Jan 24, 2005 07:24 PM
