Running bad, then no spark
Old Dec 8, 2019 | 10:10 AM
kazmohdim's Avatar
Hello everyone. I drive a 1985 4Runner with a 22re.
This all began with performance issues. It was rough idling, low power on acceleration, it misfired once or twice. Figured it was timing issue. Timing was more or less fine with a timing gun. Got a visual on the timing chain. Everything at top dead center looked fine. I foolishly assumed it must be the ignition coil without really thinking much of it. So I replaced it. After that, now I get no spark. I can smell gas as I crank the engine so my injectors and fuel pump work.
Been racking my brain for days trying to figure out what the hell is going on.
Old Dec 12, 2019 | 11:45 AM
old87yota's Avatar
Do you have your old ignition coil?
If so, put it back in and see if you get spark.
If not, post back up here and we can help you diagnose the no-spark problem.
Old Dec 13, 2019 | 09:29 AM
MaK92-4RnR's Avatar
What's the status of your distributor's rotor? Ever changed it?
SueLu
Feb 24, 2016 08:23 PM
timtoyo
Oct 16, 2013 11:50 PM
vsi1600
Apr 3, 2010 11:15 AM
maicomega1
Jan 7, 2010 09:24 PM
routeip
Apr 22, 2003 12:26 PM
