Rebuild has a loud rattling on top
I just rebuilt a lower end of a block for my 85 runner 22re. I reused the top end from my old engine. I replaced it because I had a bad piston slap. Now I have a loud rattle. I have 20psi for oil pressure at idle, all new parts in the lower end and they all meet clearances. I have oil getting to the top end. but I'm not sure if its enough. I removed the timing chain cover last night to make sure the plug was in, but with 20psi I think all the plugs are in. I'm going to drop the oil pan tonight to make sure the one below the sending unit is there. Any other suggestions of where to look for problems would be greatly appreciated. Oh yeah new timing chain, guides, and tension. I also adjusted valves 2 times. first time was to stock, then to a little tighter then stock.
I had a buddy say the piston pins might not be getting oil. Does anyone know how the piston pins get oil, or a diagram of the route the oil goes. I can track it up to the head then I'm lost.
and if the pins weren't getting oil, well then prepare for another tear-down to see why
do you have enough oil in it?
Either way, make one thread and stick with it. I hate when people make two threads for the same problem, especially when they're brand new members because the forum rules should be fresh in your head.
I am new.. I posted on the 84/85 section and didn't see any one on in that section so I posted on the 86 and new section thinking that they were different. Now I know that its available to see under the new post section so It won’t happen again.As for the original question. I would assume that the piston pins are getting oil from what the crank splashes up?? Also the crank pulley was torqued down.
I put in almost 5 quarts. I think Monday will be a cylinder head removal day..... again....
