Rear wheel cylinder on 10/85 build date
Old Mar 10, 2008 | 10:46 AM
patallen's Avatar
Hi, i have a 10/85 build date 4x4 with long bed.
guys at parts store are totaly confused which wheel cylinder to get...so i am.
is there any upgrade that i can do ?
i searched, didnt find anything about the rear wheel cylinder themselves, only the MC.
It got already IFS with vented rotors and big drums (oem).
thanks for any comments.
Old Mar 10, 2008 | 11:23 AM
DeathCougar's Avatar
what options are there? Are you telling him 85 or 86? 10/85 is an 86
All 4x4 86 trucks use the same wheel cylinder.
Old Mar 10, 2008 | 11:35 AM
patallen's Avatar
well, he ask me for the build date, but also if it is a 1/2 ton or 3/4 ton.
looooong time ago, the dealer told me it was a 85 1/2
I always say its a 86'.
no upgrade (larger cylinder) ??
thanks.
Old Mar 10, 2008 | 11:53 AM
4Crawler's Avatar
thanks.
What is the front suspension? A leaf spring/solid axle or IFS w/ torsion bars?
Old Mar 10, 2008 | 12:02 PM
patallen's Avatar
I mentioned in my first post that it is a front IFS (with torsion bars)...mostly a bone stock long bed early 86'.
it has the large drums at the rear.
thanks.
Old Mar 10, 2008 | 12:06 PM
4Crawler's Avatar
Well, you have the big brakes in back, so the stock part is fine. I would get one from a Toyota parts dealer, just take in your VIN number and they can fix you up.
Old Mar 10, 2008 | 12:11 PM
patallen's Avatar
perfect, thanks...
since i have your attention...i plan to add a snow plow on this truck. since it is a IFS, there is no coild spring to play with.
is there something that can be added like a coil-over helper ??
thanks.
Old Mar 10, 2008 | 02:48 PM
You can add heavy-duty torsion bars to offset the weight, or go on the cheap and just crank them up a little bit....be advised thats not the best way to do it since you will have a harsher ride, and risk damage to the bars from the added stress.
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
icentropy
Jul 9, 2015 02:12 PM
skoti89
Jul 6, 2015 07:45 PM
toyoda8488
Jul 5, 2015 10:18 PM
