Rear Springs
Old Aug 22, 2006 | 04:17 PM
Rear Springs
Does anybody know if rear leaf springs off a 85 4-Runner fit a 87 truck?
Old Aug 22, 2006 | 04:24 PM
AH64ID's Avatar
I do beleive so.. it wasnt until the new body style that they were lengthened
Old Aug 22, 2006 | 04:30 PM
Good, I have a good deal on a set! thanks
Old Aug 22, 2006 | 05:14 PM
Tofer's Avatar
Sponsor
would that give some lift since the 4runners would be heavier in the rear? i just picked up a trailer made out of an 81 or 82 shortbed... and now i want to lift it.
Old Aug 22, 2006 | 07:55 PM
4Crawler's Avatar
Yes, they will fit. I don't think there is any spring rate difference between the pickups and 4Runners. That is why the 4Runners all suffer from butt-sag
Old Aug 29, 2006 | 01:26 PM
fourwd1's Avatar
If you want a little lift use the rears off of a 2WD truck. They have a little more arch since the 2WDs are SUA while the 4WDs are SOA. So mounted SOA you've got lift.
Old Aug 29, 2006 | 03:58 PM
AH64ID's Avatar
they also sit about 1' lower than a 4x4.....and a SOA is only about 4-5" worth..not sure it would lift your rig at all, probally lower it.
Old Sep 1, 2006 | 02:40 PM
titicaca's Avatar
the 2wd springs fit but they will lower the truck about an inch or so, they are a softer spring, i did an soa on a lifted 2wd and gained about 5-6 inches of lift, the lift is simply the diameter of the axel and spring thickness, not really anything to do with the springs.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
terminator
Jul 27, 2015 07:13 PM
yourrealdad
Jul 21, 2015 11:13 AM
Nickdigg
Jul 7, 2015 06:04 AM
