Rear main & Rear ou put seal blown in a month?
Old Jan 6, 2013 | 02:39 PM
ojm3's Avatar
Hey guys i got an 84 pickup. About a month ago i had my rear main seal, as well as the rear output seal replaced on the transfer case. Simultainously over the weekend they both went out. i got both the seals at autozone. Where can i get good seals!? Whos got a good brand?
Old Jan 6, 2013 | 02:45 PM
rokblok's Avatar
Did your do the work yourself, or did a shop do it? If you're not very careful, it's very easy to roll the lip on a seal, or the retaining spring on the seal could have popped off, or the groove in the shaft you're sealing may be to deep and not sealing, the seal lip could've been nicked/cut. There are lots of reasons for leaking new seals.
I tend to use National, and I've never had an issue. But I also am very careful with installation, I put a bit of grease on the retaining spring, and I check seal fitment on the shaft and groove before I install completely. And I use a small coating of Ultra Black on the outer diameter of the seal.
Old Jan 6, 2013 | 02:56 PM
ojm3's Avatar
I had a mechanic replace them. he said he had a tough time reattatching the engine to the tranny so im sure he messed up the rear main a bit before he got it on. I can just about guarantee he didnt lube anything. But for both seals to go out at the same time...im guessing crappy quality. To tell the truth it looks like my valve cover seal which i replaced at the same time is starting to get shiny as well. Someone told me its because i had a vacuum line capped off, and the pcv valve left open. but idk how cause ive seen breathers where they should be pcv valves on certain 22rs
Old Jan 6, 2013 | 03:47 PM
rokblok's Avatar
My 22R had two hoses coming off the valve cover. One for PCV valve and one to the air filter housing.
It could be either bad seals, not highly likely, or bad install. If you run a seal dry, it will scorch the rubber and it cannot seal. Good quality seals generally come with a little grease on the seal lip.
Old Jan 6, 2013 | 03:59 PM
ojm3's Avatar
same here. I'm guessing a bad install. I will ask tomorrow but I'm sure the mechanic didn't grease any seal. so ill be redoing the three if them myself with grease and lce engineering seals.
Old Jan 6, 2013 | 04:15 PM
rokblok's Avatar
Good luck bro. See if the lip retaining springs are still there on the seal lip.
Old Jan 6, 2013 | 04:48 PM
ojm3's Avatar
thanks rok. would I be able to see those Springs from the bottom of the engine before I pull it or not?
Old Jan 6, 2013 | 08:49 PM
rokblok's Avatar
Negative. The springs are on the inside of the seal. Once removed, or on a new seal, you can see the spring on the inside lip. This keeps tension on the seal lip. Examine the old seals for any damage or a hard lip. It won't be supple like a latex glove, but it shouldn't be rock hard either.
Old Jan 7, 2013 | 06:29 AM
ojm3's Avatar
thanks rok much appreciated
voiddweller
19
May 2, 2016 09:10 PM
Alaskan91
Sep 21, 2015 04:39 AM
cchinny
Jun 25, 2015 08:11 PM
Grimace
Jun 11, 2002 05:56 PM
94 First Responder
Jun 6, 2002 02:19 PM
