Rear electrical window switch??
Old Dec 7, 2009 | 02:08 AM
TinMan's Avatar
Does the rear window go up with the exterior key switch or just down. I ask because mine only goes down, The key will turn in the oposite direction, but it does not do anything, no clicks, nothing. So did a little trouble shooting yestarday. The FSM says to test cont at the switch connector at pins 1 and 2(up). There is not wire in pin 2 in either side of the connector. It is capped off on both sides.
Old Dec 7, 2009 | 08:59 PM
stormin94's Avatar
Sounds like your key switch is shot. Mine used to go up and down, then it would only go down. Now it doesn't do either, so I have to use the switch inside.
Jun 1, 2021 01:51 PM
coryc85
Sep 9, 2015 06:24 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
coryc85
Jul 6, 2015 04:07 AM
