Quick question about the SR5 oil pressure sending unit
Old Aug 28, 2009 | 10:26 PM
rsidner's Avatar
So I have the SR5 oil sending unit on the side of my motor.
I am looking at the ECU pinout for the 22re and I don't see anything labeled on it for the oil pressure gauge. Does anyone know or able to tell me which wire that comes down from the intake manifold should connect to this sender?
Thanks!
Old Aug 29, 2009 | 08:30 AM
LD's Avatar
LD
there's only a few single wires coming out of the harness. if you can narrow it down to a couple , with ignition switch to on: ground the right wire and your gauge will peg to the top. no ECU pin.
Old Aug 29, 2009 | 08:49 AM
4Crawler's Avatar
Generally not a good idea to short the wires to the analog gauge (OK with the idiot light). Why? The gauge works by putting a known voltage across the sender resistance and registering the resulting current on the gauge (Ohm's law: I = V/R). Problem is when you short the connector pins, R=0 and things go boom!
Old Aug 29, 2009 | 07:48 PM
rsidner's Avatar
I'm pretty sure that I got them sorted out.
Old Aug 31, 2009 | 05:00 PM
brownbagg's Avatar
the ecu doesnt control the oil gauge, which one hooks to it? the only one with the matching plug to hook to it
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Colington
Mar 8, 2020 09:51 AM
Cplmike
Jul 8, 2015 08:47 PM
HRDC0R19
Jul 5, 2015 06:43 PM
