Question about swapping diffs
Old Jun 10, 2013 | 10:39 PM
noble's Avatar
Hey All,
Just a question. Pondering buying an 85 w/ a solid axle and giving up my 95 that has had some work put into it. The question I pose is will the 1995 rear differential (it is re-geared and locked) fit in this hypothetically new 4runners stock rear axle? Also, in the same vein, would it fit in the front axle? Are they all the same 8" size?
Thanks in advance,
Pat
Old Jun 12, 2013 | 03:32 PM
gigatech88's Avatar
1985 pickup, 4runner? also the same question for the 95.
Old Jun 17, 2013 | 01:06 PM
ab0tj's Avatar
The rear from the 95 should fit in the front or rear of the 85. But be aware that the gears in both diffs need to match if you plan on using 4wd.
jerusry
Oct 19, 2015 05:28 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
KBar
Jul 13, 2015 06:01 PM
Coreyr384
Jul 10, 2015 11:13 AM
