Pulling apart driveshaft
Old May 17, 2011 | 12:23 PM
Taco Eater's Avatar
I need to redrill my flange on my third member to accept my u joint bolt pattern. Can I pull the outer larger part of my drive shaft off so that I can better position it as a template to drill with? My only assumption is that I can do it but I'd want to mark the two sections so that they go back together on the same splines.
Old May 17, 2011 | 12:31 PM
justin_4runner's Avatar
yes u can pull them apart, just mark with paint or something so when u put back they will go back in the same splines.
Old May 17, 2011 | 01:31 PM
Taco Eater's Avatar
How important is it to line up the splines? I just pulled it out and forgot to mark them.
This is my rear shaft by the way.
Old May 17, 2011 | 03:17 PM
85TurboRunner's Avatar
As long as you don't have any vibrations then there isn't a problem.
The drive shafts are balanced at the factory. I've forgotten to mark them when taking them apart and have never had an issue.
4x4-runner
Apr 18, 2017 09:08 PM
mussy01
Dec 13, 2016 08:20 PM
Tonetrk
Aug 6, 2015 10:06 AM
gillesdetrail
Aug 3, 2015 04:43 PM
Sr5crawler
Jul 31, 2015 12:32 PM
