please HELP!85 22re injectors not firing
Old Feb 23, 2010 | 11:50 AM
1985chevota's Avatar
hi im pulling my hair out tying to get my yota goen. i put a noid light on the wires for the injectors and nothing but if i use a test light i get power at both wires when the key is on and im cranking it. i can put gas down throttle body and it runs the gas out.also if i put noid light on cold start injector it lights up so that works. PLEASE HELP!
Old Feb 23, 2010 | 11:55 AM
M4Runner's Avatar
similar problem with mine, the injecors werent getting a signal. i replaced my computor and that fixed it
Old Feb 23, 2010 | 03:15 PM
Firefightertaco's Avatar
do you have the air intake and the afm connected
Old Feb 25, 2010 | 07:36 AM
still un sure?? (computer)???
yes the maf is hooked up and checked everything. think its the computer?? i dont get a check engine light at all except when i put a test light on the check engine wire coming from computer.?? what does that mean? i have a 1985 and i was told that 85 stands alone, soo i have to have a 85 computer if ne can help that would b GREAT! And if i cant find a computer i think im just gana pull it out and put the 4.3 vortec in!! Thanks (its driving me 2)
Old Apr 8, 2010 | 05:08 AM
takeitoutgetitdirty's Avatar
check the wiring harness for two ground wires that goes to one ring, it should connect to the intake that is the ground for the ECU to ground the injectors for pulsating. At least that is what was wrong with mine when I had the exact same problem.
Old Apr 8, 2010 | 07:01 AM
4Crawler's Avatar
See below:
- http://www.4x4wire.com/forums/showfl...&Number=759362
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Sandman
Jul 14, 2015 12:36 PM
