Play in steering... Steering BOx?
Old May 13, 2008 | 02:27 PM
DATTOY's Avatar
So My 85 Pick up has about 2 inches of play in the wheel. I am trying to determine if its the steering box, and if i can do anything about it. The previous owner installed crossover steering, the box looks clean and new. But if i move my steering wheel the two inches back and forth the shaft moves seamlessly with the steering wheel but the pitman arm dosen't move at all. ???? are there adjustments on the steering box..
Old May 13, 2008 | 03:02 PM
eric-the-red's Avatar
The box on my 93 had an adjustment on the top. It looked like a screw with a locknut on it. If you can see that loosen the locknut and turn the screw in until you get less play. The manual says 1" at the rim of the steering wheel is normal.
Old May 13, 2008 | 03:12 PM
DATTOY's Avatar
Thanks i'm going to go take a look.
Old May 13, 2008 | 03:56 PM
DATTOY's Avatar
I think it worked. I basically tightened that screw down all the way, and the steering is way tighter. and a little harder to turn at first, but that makes sense considering that before it wasn't doing anything. Can you tighten it down to much?
Thanks
Old May 13, 2008 | 03:58 PM
4Crawler's Avatar
I run mine snugged down all the way, no problems. Assuming you are tightening the screw with a long bladed screwdriver, I doubt you can make it too tight. Maybe if you had the box off the truck and used an impact gun on it, it may get too tight.
Old May 13, 2008 | 05:33 PM
DATTOY's Avatar
yep just used a screwdriver. Sweet deal! That was alot eaiser than i thought it was going to be.
Old Aug 27, 2008 | 12:21 PM
Nix_Toy's Avatar
Is that adjustment only on IFS steering boxes?
Old Aug 27, 2008 | 08:16 PM
jodaddy's Avatar
power steering and manual steering boxes both have an adjuster
Old Aug 27, 2008 | 08:24 PM
rowdy235's Avatar
Never mind, misunderstood question
4x4-runner
Apr 18, 2017 09:08 PM
delmert
Sep 30, 2015 04:34 PM
Scotto6591
Sep 1, 2015 03:24 PM
4x4-runner
Aug 30, 2015 08:55 AM
4x4-runner
Aug 2, 2015 09:24 AM
