Pinion Bearing Preload?
Old May 15, 2012 | 09:38 AM
beatupbrown87's Avatar
8" 4cyl diff. FSM says 16-22inch pounds with new bearings and the instructions that came with my new Motive Gear 4.88's say 25 inch pounds with new bearings. I set it up with a solid collar and got 20-22 inch pounds rotating, then I assemble the rest of the third .0094 B.L. and some good carrier bearing preload. This results in about 35-37 inch pounds overall preload, it feels way too tight to me with my limited experience. What should overall preload be on a good setup?
Old May 15, 2012 | 10:40 AM
bobbybouche's Avatar
I like my pinion preload @ 16 in#s
.007 backlash
125 ft#s on the carrier preload
Just make sure your pattern is spot on.
I'm running a v-6 3rd with 4:88s
Old May 15, 2012 | 11:10 AM
BMcEL's Avatar
Old May 26, 2012 | 07:50 AM
deserttoy84's Avatar
I would leave it alone as far as the pinion preload goes. its always gonna be higher when you install the carrier. measurement is without it.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Odin
Sep 26, 2015 06:56 PM
