Overdrive not working--which solenoid do I get? (85 Pickup A340)
Old Aug 28, 2014 | 01:51 AM
eazhar's Avatar
Hey guys, I recently came back from a long drive from LA to Phoenix. I noticed on my way back that I lost overdrive, and ended up driving back in 3rd the whole time.
The pickup shifts in all the lower gears just fine, without slipping, and the tranny fluid also seems adequete. However, it just seems to refuse transitioning from 3rd to OD.
For a while, before this started, it had been slipping from OD to 3rd on the highway. Like I really had to let go of the gas to keep it in OD. Additionally, i have now notice that when I push the Overdrive button on the shifter, the light on the console does not come on to indicate that OD is off.
I have concluded that what I need to replace is the "overdrive solenoid," whatever that is after reading a few forums and threads posted here,
After checking at my local O'reilleys and looking at eBay and google shopping, I am still not sure what to purchase and from where.
Oreilly's told me to get part number 18-1722 Import Direct Ignition - Transmission Switch ($160)
Link
But I found something similar with a different name on ebay, part Standard Motor Products TCS33 Automatic Transmission Solenoid ($140)
http://www.ebay.com/itm/Standard-Motor-Products-TCS33-Automatic-Transmission-Solenoid-/400750560660?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AToyota%7CModel%3APickup&hash=item5d4e984594&vxp=mtr
But I also found this thing called a kickdown solenoid on eBay ($320)
http://www.ebay.com/itm/Auto-Trans-Kick-Down-Solenoid-WORLDPAC-W0133-1741318-fits-85-91-Toyota-Pickup-/221532740184?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AToyota%7CModel%3APickup&hash=item3394615a58&vxp=mtr
And a cheaper one on Google ($240)
Link
Which of these should I be getting? And on top of that, am I even on the right track and replacing the right thing? Under normal circumstances I would certainly purchase both, but they are both a lot more costly than I would have expected.
Old Aug 29, 2014 | 08:45 PM
vital22re's Avatar
totally a bro
Is your thermostat working? Often, if it fails and the coolant temp doesn't hit operating temp it wont kick in OD. Just a thought.
Old Aug 30, 2014 | 01:27 AM
Terrys87's Avatar
Put your VIN number into toyotapartseast.com and it will tell you what part numbers your truck needs.
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
mengquis
Jul 13, 2015 10:39 AM
Jnkml
Jul 6, 2015 01:20 PM
