Outer Hub Gear Getting Stuck in Lock Position
Old Jul 30, 2019 | 01:03 PM
DIRT8IKE's Avatar
So I just recently did an SAS on my 87 so I'm at the point where I'm chasing down loose ends and little problems. One of those problems is that when I lock my hubs they lock but when I turn to free the gear doesn't retract from the inner gear. They are in an IFS hub body so I have the new chromoly inner conversion gear and I upgraded the outer to chromoly at the same time. I am 100% certain I assembled the pawl assembly right as everything is still holding together.
That outer hub gear just isn't pulling back out into the free position and I was wondering if they maybe just need to wear in a bit or if anybody else has encountered this?
Old Aug 5, 2019 | 11:53 AM
maco35's Avatar
Here, it's easy to take it apart grease it and put it together....https://forum.ih8mud.com/threads/reb...ebuild.149776/
Old Aug 5, 2019 | 12:05 PM
maco35's Avatar
Just keep an eye on the small bearing and spring, don't loose them.
Old Aug 15, 2019 | 09:56 PM
Winky29's Avatar
Hey,
I’m not sure if this will solve it but this video by Wheelie Pete on YouTube (no affiliation) shows how to assemble the outer hub dial. I guess if you get the spring put on wrong it’ll lock but won’t unlock.
Hope this helps.
Winky
woodyth
Sep 2, 2012 02:29 PM
hunter h
Jan 13, 2011 08:40 PM
iamsuperbleeder
Apr 8, 2008 09:48 PM
jagger_snitt
Jan 26, 2008 12:42 PM
gilkey
Oct 21, 2005 06:39 AM
