OME for Roland
Old May 14, 2021 | 06:29 AM
ArcticTaco's Avatar
OME for Roland
Greetings all,
A little back story.
I am planning to go OME on my 85 Toyota pickup. Right now it is perched on the stock springs with a few -2 up front 3- aft, leaves from a 79 Toyota SR5 -3/4 ton( that’s what it said on the title) 2WD truck. Apparently the rear suspension had been augmented by the PO, re-arched. It looks like they added 2 AALs I think.
It’s a budget build, so after I cleaned the packs up and got them re-installed and it rode like a beet truck with the stock shocks. Replaced the shocks with some SkyJackers( I know- remember budget build?) and that cleaned it up some, I ended up pulling one of the AAL from the rear, to soften the ride some. I had to put about 350# to get it a bit softer.
Looking for about a 2-3” lift.
It is mostly a commuter-90 miles of gravel road once a week, with a fair bit of towing, due to the first stages of bed cancer, the long term plan is replace the bed with a flatbed and topsider boxes, with a lumber rack., and a regear with either 4.88/5.29 still not sure about which route on gears.
On the fence about the Nitrocharger shocks , I’m down with the rest -springs, shackles, just not sold on the Nitros, thinking about maybe going with Bilstein or Rancho RS9000xl. Thoughts?
Disclaimer- I do have a hybrid OME setup on my Tacoma, 883s w/Bilstein 5100, and the OME Exp HD w/AAL and Bilstein aft- might be adding another AAL just for weight, and the AlCan has some pretty beastly frost heaves. Absolutely love the ride, plan to keep this setup until I can get a wedge topper , then I may go custom. At that point.
Pics:
Roland on the way to work
Roland in the throes of spring rehab
Roland post spring work -last two
Roland will be getting an engine swap in June.
Roland on the commute
Roland during spring rehab
Roland post spring rehab
Roland commuting after the landslide
Roland hanging out with the big kids... you can see a bit of the ‘draggy butt syndrome’....
_RaStA_RoCkEt_
Sep 28, 2020 09:11 AM
demonwaif5
10
Oct 8, 2018 09:29 AM
Neomonk
15
Jun 8, 2011 08:06 AM
Strap22
Aug 23, 2005 11:53 AM
RobG
Dec 13, 2004 12:20 PM
