Neomonk's 1994 Toyota 4Runner (Build-Up Section)
Just starting this thread so I can come back to it....
1994 Toyota 4Runner SR5 V6 4x4 15,000 miles.
Green's Peak, AZ
Gunsight Pass, AZ
New Tires
Smiley Rock
Sedona
White = Current Mods
Green = New Mods
Blue = Bought But Haven't Been Installed
Orange = Want To Have
Red = Taken Off
MODS:
SUSPENSION/DRIVETRAIN:
FRONT:
OME N98 Shocks
OME SD33 Steering Stabilizer
1.5" 4Crawler BJ Spacers
Aisin Manual Locking Hubs
REAR:
OME HD901 Springs
OME N72F Shocks
Panhard Drop Bracket
LSPV Bracket
Aussie Locker
WHEELS/TIRES:
Cragar 342s Black Steelies 15x8x3.75
BFGoodrich KM2s 33x10.5R15
EXTERIOR:
Cobra HG A1500 Mag Mount Antenna
Diamond NR-770HB 2m/70cm HAM Antenna
LightForce 140 HIDs
Custom Rock Sliders
Custom Roof Rack
Undercarriage Lights
4' CB Antenna
4' Firestick 5/8 Wave CB Antenna mounted at tailgate
Firestick Spring SS-3H
Firestick Quick CB Antenna Quick Release
INTERIOR:
Sony Stereo Head
Boston S45 4" Speakers
iCOM ic2100h 2m HAM radio
iCOM HM-133S Mic
Comet 3D5M UHF Coax
Comet RS-660U Luggage Rack Mount
MFJ 281 HAM Speaker
Midland 1001z 40 Channel CB
GlobalSat BU-353 GPS Puck
SPOT Personal Tracker
Kenwood KSC-WA801 Subwoofer
Cobra S600 External CB Speaker
750W Power Inverter
CO2 Tank System
ENGINE:
BlueSea 5026 12 Slot Fuse Panel
BlueSea 185-Series Circuit Breaker
Optima Red Top
Green's Peak, AZ
Gunsight Pass, AZ
New Tires
Smiley Rock
Sedona
Green = New Mods
Red = Taken Off
MODS:
FRONT:
OME N98 Shocks
REAR:
OME HD901 Springs
OME N72F Shocks
LSPV Bracket
Aussie Locker
WHEELS/TIRES:
EXTERIOR:
LightForce 140 HIDs
Custom Rock Sliders
Custom Roof Rack
4' CB Antenna
INTERIOR:
Sony Stereo Head
iCOM HM-133S Mic
Comet 3D5M UHF Coax
MFJ 281 HAM Speaker
750W Power Inverter
CO2 Tank System
ENGINE:
Optima Red Top
well hello there nice to see you here also i haven't started a build thread yet but i am going in the same direction mine is a 90 3.0 with extensive mods to the engine (not done by me)engineis balanced and blueprinted bored .30 over forged pistons moly rings,biger stainless valves,heads are ported and polished,intake as well bigger thorttle body lc air intake, has plenty of get up and go. just installed 97 lc coils in rear got 4in of lift just orderd bj spacers and drop brakects (brackets are for the rear) should have them in next week hopefully gets rid of the stinkbug look. anyways nice to see you here we'll have to get togehter sometime. nice build buy the way
New Parts Have Arrived
Received a few new parts...to be installed soon. I'll try and take photos.
Also, wheels and tires going on this Saturday, May 28 2011.
4Crawler 1.5" Ball Joint Spacers
Blue Sea Fuse Panel with 100A Circuit Breaker
what wheel and tire combo are you going with? i haven't ordered my wheels yet but i'm going to try 285/70/17 on black steel wheels with 20mm offset and see if that works. hopefully i will have the funds next week to get the wheels then i can finally do the bj spacers.
I've ordered 33x10.5R15 on Crager 342 D Window black steelies, 15x8 with 3.75" back spacing. You should be able to fit the diameter of that tire and the width is about 11" so not bad. The only number that would concern me is the 20mm offset. You would want to double check that 20mm is similar to 3.75" BS.
$100 a year is a little pricey but that one time, hopefully years and years from now, that I have to use it, it'll be worth the cost.
The device is a good price right now here:
http://shop.sailnet.com/spot-satelli...id=17052011s10
$39.99 after the mail in rebate so I went ahead and purchased it.
and that off set was for the stock 17 inch tacoma/4runner wheels that where already on it. the wheels i ended upgoing with were the unique 17 steelies with a 0 off set so the hub mount is right in the middle of the wheel so far i got the back on and it looks like the spacing is going to be right on now to get the front done and go flex it to see if it rubs anywhere.
Crazy_Guy97
12
06-24-2015 04:02 PM
JaredL
06-16-2015 04:47 PM
