Oil Pressure!! Won't Hardly Build,, BIG problem!
Old Jul 15, 2009 | 10:02 PM
Gameover209's Avatar
Originally Posted by TrevanO
gameover, 4 quarts fill a 22re. Not sure what the problem could be, does your dipstick go all the way in to the pull gaurd? if it noticably sticks out and isnt hitting near the bottom pan you wont get a good read.
yeah i gt the 94 v6. guy at autozone said it takes 4.75 qts. so im thinking the dipstick might be da problem. maybe its an aftermarket one and is shorter than the original? im prolly gna go to the dealer and ask em if they have a stock dipstick just for peace of mind lol
Old Jul 16, 2009 | 05:14 AM
ozziesironmanoffroad's Avatar
also depends on the size of the oil filter. 4 qts does NOT 100% fill a 22re with a filter, after the truck is started. according to mitchell at work, oil capacity with filter and warm engine is 4.40qts. put in 5.5 qts and you should be reading fine. chances are the dipsticks fine.
and x2 on oil pump.
Old Jul 16, 2009 | 01:40 PM
hmm alright well i got the 3.0 but if this is so ill probably go ahead and add another half quart on top of the 5 i already added and c if it gives me a good reading
Old Jul 17, 2009 | 03:40 AM
flashkl's Avatar
my 3.0 take 5 quarts with the larger than OEM size NAPA gold 1516 filter. Somethings not right here....
Old Jul 17, 2009 | 11:14 AM
  #25
TrevanO's Avatar
Exclamation
Back to the subject of the thread, i took the oil filter off yesterday and it seemed to be clogged with a silicone, i cleaned it off and put a new filter on STILL getting really low oil pressure, Like i said i recently changed the timing chain and from the looks of it the oil pump looked fine but at the time i wasn't looking for any damage or wear
Old Jul 17, 2009 | 08:12 PM
  #26
rowdy235's Avatar
Have you checked the sending unit? My jeep's sending unit got plugged with a little piece of sludge and would read low. Pulled it out and hit it with some brakleen and it read properly. Just an idea...
Old Jul 18, 2009 | 10:14 PM
  #27
TrevanO's Avatar
thanks dude, tried that today but still no luck
miah
Jul 6, 2015 06:39 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
