No gauges/turn signals
Old Aug 6, 2009 | 06:12 PM
seanmearse's Avatar
So I went out wheeling with a friend today, all day. Got to the top of a hill about three hours into the day, checked out some piles of parts, redneck style. Well, i get back in the truck, start it up, and no tach., no oil pressure, no volt reading, yet everything else is functional- stereo works fine, headlights work fine, e-flashers work fine, brake lights are fine, gauge lights are fine, back up lights are fine, and runs same as usual. I checked the 9 fuses in the fuse panel, all were good. Also checked the fuses under the hood. Had the cluster pulled while out there, all conections are clean and plugged in. I cannot for the life of me figure this out. I did try search, all I found was cluster swaps and light bulb changing. Anyone have an Idea? Is there a fuse I might have overlooked?
edit--- Or a relay?
Old Aug 6, 2009 | 07:08 PM
seanmearse's Avatar
Nobody has any ideas? This sucks cause the cops here are the worst. Can't drive it until it has turn signals, but I know the two are related.
Old Aug 7, 2009 | 08:03 AM
seanmearse's Avatar
nothing, eh?
Old Aug 7, 2009 | 08:14 AM
Lumpy's Avatar
Just so you are not being ignored...I'm not sure. Maybe you pinched a wire in the steering column? Seems like one of the relays are not getting power or is stuck. Pull the relays out and test them maybe give them a little tap. Not a BFH smack but a lil tap with the plastic handle of a screw dirver.
Old Aug 7, 2009 | 08:17 AM
seanmearse's Avatar
k. run out and try it now, ill let you know. cant believe i didnt think of that.
Old Aug 7, 2009 | 08:42 AM
seanmearse's Avatar
nothing. There isnt even a relay or fuse labeled for the gauges. The fuse for the turn signals is still good also.
Old Aug 7, 2009 | 08:47 AM
Lumpy's Avatar
Hmmmm interesting.
Go over some of the grounds. When you turn the key "on" All those things are not working are on the same part of the key (the on position). The things that are working are either always on or on the ACC part of the key. Maybe the ignition switch is on it's way out.
There has to be a fuse there somewhere for this group of gauges and flashers. Maybe a ground or inline fuse???
Old Aug 7, 2009 | 08:49 AM
seanmearse's Avatar
cant find anything. The switch is providing power, but, that is a viable option, i will see about getting my hands on one.
Old Aug 7, 2009 | 08:57 AM
Lumpy's Avatar
Hopefully someone else here can give some insight as well.
Old Aug 7, 2009 | 12:28 PM
seanmearse's Avatar
And the idiot of the year award goes to........ wait for it....... ME!!!!!!
I went through the fuses again, just to humor myself. Did anyone else here know that if your 15 amp engine fuse blows, the gauges and turn signals will go out. But, whats wierd is the fact that the truck still ran. Im thinking someone re-wired the truck, and connected things a little bit wrong. But, yeah, now that i feel like a total idiot, time to install some new wires.
Thanks for the help Lumpy.
Old Aug 7, 2009 | 12:35 PM
Lumpy's Avatar
It's all good it happens to the best of us. Just glad you got her going!!!
Old Sep 2, 2009 | 08:05 AM
91sasPU's Avatar
Glad to find this post I just got back from a wheeling trip in my 85 runner, and same exact thing has happened no blinkers or instrument gauges; all fuses check out fine. I will go check the above things. Thanks yotatech
Old Sep 2, 2009 | 08:20 AM
seanmearse's Avatar
Ya, check that 15 amp engine fuse in driver kick panel.
Old Sep 2, 2009 | 08:36 AM
91sasPU's Avatar
hah nice call just went out and double checked all my fuses after writing that post. Wasnt really in the best state of mind when that happened and came back to edit it and say it was the 15 amp engine fuse.
Old Sep 2, 2009 | 09:14 AM
seanmearse's Avatar
Very nice.
kawazx636
Oct 6, 2021 03:03 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
calderp
Nov 16, 2015 02:49 AM
Scotttekoch
Sep 28, 2015 10:30 PM
Boomer8404
Sep 24, 2015 01:12 PM
