New owner overhaul...need advice!
Old Sep 21, 2007 | 09:24 AM
Bskey's Avatar
I just bought an '85 SR5 4Runner w/ 225k miles on her and it's been sitting for some time. I need to change out the fluids and get on a regular maintenance schedule, and wanted advice for fluids, manufacturers, etc?
Also, what are the cheap/easy mods to start with on the 22re?
Thanks!
Old Sep 22, 2007 | 10:00 AM
nspadoni's Avatar
do a full tune up adjust the vavles, and replace the timing chain if it is more than 120k old, while your there replace the camshaft and valve springs
Old Sep 22, 2007 | 11:15 AM
nix4x4's Avatar
Hell if you've got the time why not just do a complete overhaul? Assuming the body and chassis/suspension are still pretty solid and rust-free, I think it'd be well worth your time
Old Sep 22, 2007 | 03:08 PM
Bskey's Avatar
The timing belt had been done just before I bought it, but I do have a little valve tap, so I need to pull the v/c and adjust that. I am looking at the LC engineering cam shaft, but that may have to wait for a little while. For now I have quite a bit of rust I need to fight off and I need to find a good local exhaust shop to fab me up something.
What problems arise by installing 4.88 gearing with fairly stock tires? I ask because I bought it with studded snows, but want to go to 32" BFG A/T's after the winter. I want to install a Lock-Tite in the rear, and figure I should re gear at the same time. Can I do it now with the small tires without much of a problem, or should I wait and do it all at the same time?
nanhodges2733
May 29, 2020 03:28 PM
Eggslinger
Jun 8, 2019 03:32 PM
boguspiano
Dec 17, 2015 02:51 AM
matrad
Aug 8, 2015 03:00 PM
icentropy
Jul 13, 2015 10:57 AM
