New engine - no oil pressure
Old Aug 25, 2008 | 04:58 AM
coltonk's Avatar
thanks for everyone help..The oil filter is one from an autoparts store or walmart...cant remember now where I got it.. Ill replace it and see if that helps.. Ill aslo check the oil pump bolt too...
Any other suggestions???
Old Aug 17, 2009 | 04:59 PM
coltonk's Avatar
oil pressure
When I start the 4runner(after it has been sitting for a while) the oil pressure does not come up right at first. Sometimes it could take 20 seconds or so to start coming up. Ive heard this can be normal but this really anoys me. Is there anything I can do to get the pressure up sooner.
Old Aug 18, 2009 | 02:14 PM
live4soccer7's Avatar
is there enough oil in it? maybe a new sensor? It could be a little blocked/clogged after sitting for a while. Did you check wiring (shouldn't be it though). Get a mechanical guage and check it to see if it's your actual gauge or not. Just do some simple trouble shoots
Old Aug 18, 2009 | 04:45 PM
coltonk's Avatar
I guess it could be a sensor...it does have a mechanical gauge and it shows no oil pressure for about 20 seconds too (along with the top end noice that goes away once the pressure comes up)
I am pretty sure the wiring is correct too..I am just so worried about ruining the engine...
Old Aug 18, 2009 | 06:04 PM
  #25
ratstar's Avatar
Mine does the same thing, and I've got a new gauge on it. I dont know what to do different on it that would make it come up quicker. I did throw some Lucas oil stabalizer on when i changed my oil, in hopes thaat it would leave enough of a residue on everything that it wouldnt damage anything.
Old Aug 18, 2009 | 06:10 PM
  #26
coltonk's Avatar
It is very frustrating. Ive got the toyota oil filter with the one-way vale built into it (supposably). I cant think of anything on the oilpump that could cause this too.
I was really hoping someone has found out what is causing this or some after market piece that will fix the problem.
Old Aug 23, 2009 | 12:31 PM
  #27
coltonk's Avatar
This is driving me crazy
I have asked before and I got some great suggestion but I still havent been able to fix the problem.
My oil pressure take 20 - 30 seconds to start registering on the mechanical and electric gauge.
I believe that the oil is draining back into the oil pan when the engine turns off. I heard that the toyota oil filter has a back-flow preventer built into the oil filter and I am using a toyota oil filter.
I know that other people dont have the same problem...
Please...Please...Please can anyone help me with this?
Old Aug 23, 2009 | 02:47 PM
  #28
ratstar's Avatar
I actually do have the same problem. And my buddys 4runner does also. Maybe not 20-30 seconds but it does take an annoying amount of time to get pressure. And both of these are with aftermarket gauges.
Old Aug 23, 2009 | 03:46 PM
  #29
myyota's Avatar
An oil pump can wear out or go bad for what ever reason, i just had to replace the oil pump on my 86 4Runner because it went bad and chewed up the gears inside of it, i have no idea what caused it, but i replaced it with a new pump and new spline gear and everything is good again, so maybe your oil pump is bad or is going bad.
Old Aug 23, 2009 | 04:12 PM
  #30
yotainprogress's Avatar
I have a completely rebuilt motor pump and all with an aftermarket gauge and mine still takes a little time to regester and after warming up it will only read 15 to 20 psi
Old Aug 23, 2009 | 05:00 PM
  #31
coltonk's Avatar
This is a new rebuild motor with a new oil pump.. I just check and I guess I didnt install the toyota oil filter..I will try and install tomorrow and let everyone know if it helps.
Old Aug 23, 2009 | 07:30 PM
  #32
85RunnerSR5's Avatar
It takes my mechanical gauge a few seconds to register when I crank it up. I run a Toyota filter. When I first crank it up, it makes a "clack clack clack" noise for just a few seconds. Not too sure what it is. The engine was rebuilt about 2,000 miles ago. I've been wondering if it is a defective oil pump (it's brand new and I know that new parts can go bad).
_________________
'85 4Runner SR5 EFI
22RE 5-speed
Bone Stock
Old Sep 4, 2009 | 06:08 PM
  #33
coltonk's Avatar
Can anyone answer these questions
Earlier I started a thread about my oil pressure problem..
Here is a picture of my (85 4runner 22RE) oil pump.
I have taken the grears out and looked but I dont see how this this thing pumps oil. Since I am haveing trouble with it taking a long time (20-30 seconds) to build oil pressure does anyone see anything wrong??
Can anyone explain these mysteries of the universe??
Old Sep 4, 2009 | 06:16 PM
  #34
BigBluePile's Avatar
Looks good to me, might have to looked it over with the FSM and check tolerances. Have you tried putting a REAL gauge on to make sure that your oil pressure takes that long?
Old Sep 4, 2009 | 06:20 PM
  #35
4Crawler's Avatar
http://en.wikipedia.org/wiki/Gear_pump
Old Sep 4, 2009 | 06:22 PM
  #36
^^Cool!!
Old Sep 4, 2009 | 06:48 PM
  #37
Kiroshu's Avatar
Yea just like that animatied pic up there it uses 2 gears to pump oil as i passes through both gears and is forced in a hole. Any who your gauge may not be working properly. Is there bookoo engine noise to where it seems like lack of oil? You can try replacing the pump but your guage might be fualty.
Old Sep 5, 2009 | 05:43 AM
  #38
coltonk's Avatar
Ths is a fairly newly rebuilt engine with a new oil pump. It has always taken a long time to build oil pressure..
Old Sep 5, 2009 | 05:55 AM
  #39
dropzone's Avatar
Fossilized
was the oil pump primed correctly when installed?
https://www.yotatech.com/forums/f116...priming-78784/
Old Sep 5, 2009 | 04:57 PM
  #40
Kiroshu's Avatar
Is there oil in the engine? Or even enough? Should be full.
