New Aap
Old Nov 16, 2007 | 08:03 PM
84yota4x4's Avatar
New Aap
so i found an aap that is sold individually but will it fit? i found it here would it fit and 84 p/u? http://www.jegs.com/webapp/wcs/store...10002_11640_-1
Old Nov 17, 2007 | 06:51 AM
slacker's Avatar
if my memory serves .. the aap is a "triangle shape" only 3 holes . the acceleration pump is 4 hole and square .
edit .. found a pic for you .
Old Nov 17, 2007 | 07:05 AM
ydopen's Avatar
I swapped out my aap and still having problems with cold start do I need to swap out the acceleration pump next?
Old Nov 17, 2007 | 02:29 PM
ydopen's Avatar
Swapped out accelerator pump today so I will fire her up in the morning and see what happens
Old Nov 18, 2007 | 05:09 PM
ydopen's Avatar
just fired it up hit it 2 pumps and it fired up and stalled hit it 1 pump and it fired back up. When it gets cold in a couple of days that will be the test? I replaced the the pump diaphram.I know the old one was 24 yrs. old but it looked o.k. to me but there might be more to it than meets the eye?
Old Nov 20, 2007 | 02:41 PM
ydopen's Avatar
After swapping out the aap and the accelerator pump diaphrams it is cranking great but it has been every day.and in warm weather it is fixna get cold and it will sit next week while at work that will be the real test. I should of swapped them out years ago.
Old Nov 20, 2007 | 05:53 PM
84yota4x4's Avatar
was it hard to swap them out? am i just swapping the diaphrams? im confused...
Old Nov 20, 2007 | 05:57 PM
84yota4x4's Avatar
also if i pump it even once b4 starting it...it takes even longer. seems almost like its flooded after one pump...
Old Nov 20, 2007 | 06:02 PM
ydopen's Avatar
They are just diaphrams with a spring easy to change. They didn't seem to have any holes in them but I can tell a differance. I bought a carb rebuild kit from autozone and have been using parts off it. I use to have to pump it ten times then it still didn't wan't to crank
Old Nov 20, 2007 | 06:10 PM
84yota4x4's Avatar
i bought a rebuild kit to from auto zone but i was just unsure about it. yea if i go out and try and start my truck it cranks and cranks for like 30 seconds until it catches and fires up, then runs like a dream except when i floor it it boggs down then speeds up.
Old Nov 20, 2007 | 06:24 PM
84yota4x4's Avatar
you think if i replaced those things it would help? how long would you say it took you?
Old Nov 21, 2007 | 05:00 AM
ydopen's Avatar
Not long just study the diagram on this page of the aap and accelerator pump or the rebuild kit should have come with one also. both of them are on the front take your time and it will be easy. Let me know the status.
Old Nov 21, 2007 | 05:02 AM
ydopen's Avatar
Do you let it warm up for a few minutes then pop the gas and it idles down. If I take off in mine and its cold it would bog. Is it o.k. when its warmed up?
Old Nov 22, 2007 | 07:26 PM
84yota4x4's Avatar
yea it only bogs when its cold...and has a really hard time starting cold...but after it warms up its fine, starts fine and barely bogs.
Old Nov 23, 2007 | 05:09 AM
ydopen's Avatar
Yes swap out the two and you will be pleased. it still may or maynot bog when its cold but if you want it to last forever I wouldn't drive it cold. I just went out and tried the 83 it is 38 degrees and I gave it 2 pumps and it fired up like I shot some cocaine in it.
Old Nov 24, 2007 | 02:52 PM
84yota4x4's Avatar
haha ok i plan on doin that on monday...i will keep you posted thanks for your help.
Old Nov 26, 2007 | 09:57 AM
84yota4x4's Avatar
i ran in to a problem...how did you get to the 3 screws on the aap? its like 4 inches of space..any special screwdriver or something? HELP
Old Nov 26, 2007 | 01:33 PM
ydopen's Avatar
I have a screwdriver with the pac of innerchangable ends that go in it. I just got the one that fit the screw and clamped some small needle- nose vise-grips on it and made a sideways screwdriver. Like I said its a be patient with it job. I found my cure when I did the accelerator pump on the other side but its a good idea to do both
Old Nov 26, 2007 | 08:20 PM
84yota4x4's Avatar
oh i see... i didn't even think of that. good idea i will try that tomorrow. thanks
Old Nov 28, 2007 | 08:56 AM
84yota4x4's Avatar
well i swapped out my aap yesterday was very time consuming...but this morning,i just turned the key (w/o pumping the pedal) and it fired up real quick..then died....then i pumped it once and it fired up again and stayed running...is this just normal with carbs? also i couldn't tell if it was gas or water coming out of my exhaust..is that normal too?
