Need some assistance picking a lift kit/setup
Old Jun 30, 2011 | 01:58 PM
socal85toyota's Avatar
springs were about $80 a piece from 4wheel parts
Old Jun 30, 2011 | 02:06 PM
live4soccer7's Avatar
Socal, what was your cost on the entire suspension setup including the IFS box?
Old Jun 30, 2011 | 03:15 PM
roughly...
OME leafs $400
OME bushings/greasable pins,etc $100
ifs box $300
ifs box mount $20
high steer kit $300
u-bolt flip kit $100
shock mounts $20
ext. brake lines $80
bump stops $40
12" shock hoops $50
Shocks $300
Driveshaft from marlin $350
5" shackles $150
Old Jun 30, 2011 | 05:41 PM
Ya... seems like wabbit was right about the costs being nearly the same. This is what I'm thinking.
Install classic 3" lift with high steer etc...
put my current 33x12.5's on the truck
install bushwackers
If all seems good then stick with the setup and install 4.88's. If I don't really like it then sell the 33x12.5's (got them for $500 with 90% tread, so I shouldn't lose on them) and get 35's and install 5.29's and sit back and drink a few brews when it's done. ha ha.
Old Jun 30, 2011 | 06:32 PM
  #25
laskt9's Avatar
i dont think i saw anyone tell you about the rough country springs but i had them on mine. theyre junk. they are actually shorter in length than the stock springs and give you a horrible shackle angle and a rough ride.
Old Jun 30, 2011 | 06:43 PM
  #26
Thanks for the input. I'm kinda set on the classic lift kits at this point. I'm just looking for someone that has any photos with them being used. TG sells them and so does wabfab. All Pro has a similar setup, not sure if it is the same or not (seems different).
Old Jun 30, 2011 | 11:07 PM
  #27
So what size lift do you think for the 84 4runner in the front and back? I will be going with the classic lift. I currently have 33's and may keep them if the lift doesn't dwarf them too bad, if not then I will go 35's and regear accordingly. I also need to take into consideration how much the springs will settle as well. Also will these springs hold up over the years?
Old Jul 1, 2011 | 04:30 AM
  #28
waskillywabbit's Avatar
Project "Weasel" is 4" springs front and back. Sold the truck to my shop help and he runs 37s now fixing to tub and run 38s.
33s will look small even with 3" springs I'm afraid. The kits ride so much better than the worn out stock suspension it's hard to compare.
You were asking for 3" pics. Search user "magpie". Seems like I set him up with 3" springs maybe.
:wabbit2:
Old Jul 30, 2011 | 08:30 AM
  #29
windedwalrus's Avatar
here's what my 84 looks like with allpros 4 inch long travel springs up front and chevy 63s in the rear rolling on 33 tsl's
88sasturbotoy
Jan 30, 2026 01:57 PM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
Backcountry411
Jul 24, 2015 08:06 AM
