Need To Replace Catalytic Converter,
Old Jul 21, 2007 | 08:16 PM
myyota's Avatar
I need to replace the catalytic converter on my 84 4Runner, but the problem is that the converter on my 4Runner has some kind of sensor that slides into a tube and bolts on. im guessing this is some kind of temperature sensor ?. Now for the problem, i can find replacement catalytic converters everywere but none of them have the tube that the sensor slides into and bolts onto. So i was wondering if i bought a new replacement converter and carefully drilled a hole in it in about the same location as the stock converter and then cut the tube off the old converter and welded it onto the new converter do you think it would work ?, i sure don`t want to go to the dealer and pay around 300 dollars for a new one.
Old Jul 21, 2007 | 08:38 PM
fo_runner's Avatar
That tube u are talking about my friend is an O2 sensor. But anyways, make sure u look for a vehicle specific Cat, some universal cats won't fit well without fabrication.
Old Jul 21, 2007 | 08:41 PM
reggie 00's Avatar
I'm not sure its a O2 sensor. I have the same thing on my 83. The O2 sensor is up higher.
I replaced the cat a while back with one that did not have the "tube". I just tucked it up out of the way. Did not notice one thing different. And has passed smog at least 3 times since i have done that.
Old Jul 21, 2007 | 08:43 PM
Mister Willie's Avatar
could it be an EGT sensor?
Old Jul 21, 2007 | 09:04 PM
locked stock 84's Avatar
I can't see any reason why it wouldn't.
Old Jul 21, 2007 | 09:06 PM
reggie 00's Avatar
That was tossed around when i did the swap. But no one really knew for sure and i was of the attitude of i didn't care.
Old Jul 21, 2007 | 09:21 PM
myyota's Avatar
I know its not an 02 sensor, the 02 sensor is located in the exhaust manifold. I was told its some kind of a temperature sensor, but i can`t find any real information on what it actually does, so that why im asking if my idea above will work. I don`t want any problems when i try and smog it.
Old Jul 21, 2007 | 09:55 PM
fo_runner's Avatar
Then unbolt the darn thing out and see what happens. A lot easier than drilling a hole and finding out u messed up.
Old Jul 23, 2007 | 06:42 AM
Volcom's Avatar
My 84 had the same thing in it's cat. I didn't end up using it since I converted it to EFI I've never seen anything like that before and either had my dad.
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
skoti89
Jul 8, 2015 12:05 AM
Jnkml
Jul 6, 2015 01:20 PM
