Need hep no spark!
Old Jun 1, 2009 | 04:59 PM
sick84's Avatar
Need hep no spark!
i got a 1984 yota 4x4 with a 22r and it aint gettin no spark. i tried a new coil,ignotion control module, and a that module inside the distributor and still nothin and i checked all the grounds and plug wires and still nothin. so i need some help anybody got any ideas?
Old Jun 1, 2009 | 10:34 PM
kingbrian's Avatar
igniter?
Old Jun 2, 2009 | 05:36 AM
83's Avatar
83
Ignitor=ignition module.
Huh...that's all the stuff I went through when I had the same issue. Ended up being the ignitor, so I don't know. If the actual wires aren't carrying enough current that could do it, but I don't know if that's very common. I guess the obvious stuff that you've probably already checked, but...everything connected the way it's supposed to be? Plugged in? Fuses good? Otherwise I don't know. If you're definitely not getting spark, meaning it isn't actually a fuel or compression issue, then it seems like you've checked about everything I would be able to think of.
Old Jun 3, 2009 | 07:24 PM
sick84's Avatar
i was checking that ic regulator not sue what tht does but i unplugge it and then trie to start it later ad now it runi have no clue what happened musta been a plug in
Old Jun 8, 2009 | 10:13 AM
ToyBotz's Avatar
my 84 had the same problem, i got a new coil, still did not fix it. later i found out it was
a spark plug wire, never thought it was that because they were new with five miles on them.
zytra
Jan 24, 2019 03:16 PM
Kamaloha
Oct 16, 2015 05:13 PM
shredder4286
Oct 1, 2015 01:09 PM
voiddweller
Sep 28, 2015 11:21 PM
Rcbc92
Sep 26, 2015 03:00 PM
