my tires go \ / then / \
Old Mar 1, 2008 | 03:06 PM
Hayes's Avatar
Okay, I blew out a trunion bearing and I had the knuckles rebuilt with everything. Now my tires still go into a \ / when driving forward and when I go into reverse they go into a / \. I can't figure it out, since the knuckles were just rebuilt. Does anyone have any other suggestions?
Old Mar 1, 2008 | 03:30 PM
Elvota's Avatar
Is the diagram / \ an overhead view, or a from the front view.
Old Mar 1, 2008 | 03:32 PM
Hayes's Avatar
sorry, from the front.
Old Mar 1, 2008 | 03:34 PM
Elvota's Avatar
I was hoping from above.... was going to suggest something loose or worn in your steering components.
I assume you've checked the obvious and eliminated any type of bearing play?
Something has to be loose for your tires to change like that.
Old Mar 1, 2008 | 03:38 PM
Hayes's Avatar
I am trying to figure out what, I need to get it up on jacks and see if anything has play in it, I was just hoping for some advice before I started digging in.
Old Mar 1, 2008 | 03:45 PM
4Crawler's Avatar
How tight (or loose) did you set the knuckle bearing pre-load?
- http://www.4crawler.com/4x4/CheapTri....shtml#Rebuild
Old Mar 1, 2008 | 03:59 PM
Hayes's Avatar
I didn't do the rebuild myself. It was done to specification, I watched the guy do it.
Old Mar 1, 2008 | 04:30 PM
n16ht5's Avatar
it could do with your steering still
Old Mar 1, 2008 | 05:27 PM
jtlinna3vze's Avatar
mine was my control arm bushings.. an inch at each wheel...
Old Mar 1, 2008 | 05:46 PM
CJM's Avatar
CJM
Ball joints, tie rod ends, check the frontend over.
Old Mar 1, 2008 | 05:51 PM
DeathCougar's Avatar
Trunion bearings would indicate that he has a solid axle up front, so IFS rules fixes dont apply lol.
Old Mar 1, 2008 | 05:53 PM
did he use the correct number of shims? If not, no matter how much you overtighten the knuckle retainer nuts, it will never be tight.
Old Mar 1, 2008 | 06:03 PM
Kiroshu's Avatar
All of the tires or just the front? If its the front somethin in the alignment might be severly ed up. Do you have the bearings rebuilt at a shop? If so they prolly jsut threw it all back to gether and didn't correctly align and or connect something back. Did you check your steering system. Tirerods, relay bars ect.
__________________________________________
95 Toyota 4runner SR5 V6 3.0 Automatic 149,970 Miles
Old Mar 1, 2008 | 06:10 PM
Again with the SFA........
Old Mar 1, 2008 | 06:32 PM
Hayes's Avatar
It is SFA. All the bearings were brand new, he did all the shims by the book. The steering is a new hysteer. Had it installed just before the trunion blew out.
Old Mar 1, 2008 | 07:52 PM
Elvota's Avatar
Originally Posted by Hayes
He did all the shims by the book.
Which book?
My impression was that the shims are case by case... requiring a specific Toyota alignment tool to get things perfect.
Most people just take care to keep the shims in the right order and assume if it worked before, it will work again.
Have you jacked front end off the ground and pulled and tugged on everything? To me, that's the next step.
Old Mar 2, 2008 | 08:37 AM
Hayes's Avatar
Nothing is loose, I put it on jackstands this morning and checked everything for play. Nothing moved.
I checked all the steering components and everything was tight with no play...
Which book?
I may have to take it to a shop and have them look at it, I am just getting frustrated now...
Old Mar 2, 2008 | 09:24 AM
deserttoy84's Avatar
sounds like he put too many shims in or the bearing race popped off(hopefully he replaced the races)
Old Mar 2, 2008 | 11:22 AM
farmerj's Avatar
just curious, but did ya check the lug nutz...
Old Mar 2, 2008 | 11:45 AM
Hayes's Avatar
That I have, I am a tired guy by trade...first thing I checked.
