my 85 with bumpsteer
Old Jul 10, 2006 | 05:47 PM
85 4runr's Avatar
just finished putiing a set of yjs and crossover steering on my runner it drives and flexes fairly decent but seems to have some bumpsteer on the highway every thing seems tight and I have the steering stabilizer. Do you all think it can come from caster and shims or a drop hanger and shorter shackles will cure it or do I need stiffer springs. Will post some pics when I resize them
Old Jul 11, 2006 | 09:16 AM
fourwd1's Avatar
I have rears up front and have just a little brake/bump steer, but in my case it's because the springs are so soft. It's not a DD and I'm used to it, so it's no big deal for me.
Yours could be due to that and/or a caster problem. Your pinion should be pointing up towards the t-case for your caster to be in the ball park. If you used longer shackles or a drop front hanger, your caster will have changed. If you used (for example) a 2" drop hanger and shackles that give 2" of lift, your caster would be pretty much stock.
Old Jul 17, 2006 | 04:17 PM
rrmike's Avatar
Bumpsteer is caused by the distance between the drag link mounting points (pass knuckle and steering box) changing when you hit a bump and the front suspension compresses. If the pitman arm doesn't move the mounting point on the pass side (steering arm) has to. It should steer to the right when you hit a bump. Steer to the left when the susp unloads.
Nothing but a panhard (track) bar will fix it. It's not really that bad on mine and it doesn't bother me so I've never paid any attention to it. If you look at a lot of other rigs with crossover steering like older f-150/bronco's and Newer solid axle Fords like the superduties they all use a track bar to get the axle to move slightly to the passenger side as the susp compresses to keep the distance between the pitman arm and the pass steering knuckle constant.
Old Jul 26, 2006 | 07:12 PM
4Crawler's Avatar
Make sure the alignment specs are good:
- http://www.4crawler.com/4x4/4R_TechInfo.shtml#Steering
Then see if you can lower the draglink angle. I get no bumpsteer with mine:
Granted, the hydro-assist steering ram can help reduce bumpsteer, but I had no bumpsteer before adding that.
Old Jul 26, 2006 | 08:25 PM
85 4runr's Avatar
thanks this link shows pics of my setup allignment is good so Im thinking the soft springs or caster is my cause.
http://www.trail-gear.com/vbulletin/...ead.php?t=2025
Old Jul 26, 2006 | 08:47 PM
4Crawler's Avatar
You'll need to get the caster angle checked at a shop, unless you want to try it yourself. Find an alignment shop that will just give you a quick check, you might even find some that do that for free or a nominal cost. Get the numbers and go from there. And also, what pre-load did you use on the knuckle bearings when you installed the high steer arms? Most folks normally go to the top end of the factory specs or a bit higher.
Old Jul 26, 2006 | 08:59 PM
85 4runr's Avatar
I used my original shims for the knuckle rebuild and it came out on the high end of the specs. I assume the caster can't be changed by a shop beings it is a solid axle but they can measure it correct.In the trail gear link the pic of the front drive shaft angle I was told the front axle flange should point straight to the transfer case flange for it to be close So I was going to do a drop hanger and shorter shackles to get it close to factory spec. Also plan to work with the spings to firm them up a little. Thanks for the input also read most of the info on your site and have learned alot.
Old Jul 26, 2006 | 09:08 PM
4Crawler's Avatar
Yes, a shop can change the caster angle, but you probably want to do that yourself. That is why I suggested that you find a shop that will just *measure* the caster angle so you know where you are starting from and where you need to get to.
You can shim the axle to change the caster:
- http://www.4crawler.com/4x4/ForSale/Shims.shtml
Or you can change shackle length
- http://www.4crawler.com/4x4/ForSale/...es.shtml#FAQ12
or front hanger height:
- http://www.4crawler.com/4x4/CheapTri...ringHangerDrop
or you can even cut and rotate the steering knuckles to correct both caster and pinion angles at the same time:
- http://www.4x4wire.com/toyota/tech/rotated_housing/
I have done all the above (except the rotated knuckles) and they all work.
Old Jul 27, 2006 | 06:00 AM
85 4runr's Avatar
thanks will be working on it as money/time permits,but it is summer time and I want to enjoy it some it still dives better than a long shackled jeep I had
noble
Jul 27, 2013 10:37 PM
swapped89
Oct 22, 2011 07:08 PM
nfleuks14
Nov 13, 2008 01:50 PM
texcat101
Sep 14, 2008 04:23 PM
86tuning
Apr 17, 2008 10:30 PM
