motor help asap
Old Jun 20, 2008 | 08:39 AM
vtjeenyus's Avatar
motor help asap
so i have a 1989 toyota 4wd 22re with a blown motor
theres a guy in my driveway with a 1984 2wd 22r
my question is will it fit???????
Old Jun 20, 2008 | 10:48 AM
Volcom's Avatar
It'll fit but the wiring and fuel lines / tank are different.
Old Jun 20, 2008 | 11:27 AM
ozziesironmanoffroad's Avatar
it will bolt up, but your electronics, fuel pump, etc will be totally different. carb motor = less fuel pressure. EFI - more fuel pressure. not to mention its federally illegal to drop an engine in a vehicle thats older than the vehicle itself. (but i wont tell if you wont.. teehee)
Old Jun 20, 2008 | 12:54 PM
Oatmeal's Avatar
'84 is old style 22R (taller deck height) '85 and newer (laser block) is the same as your '89. The only thing your '89 and '84 share are the crank and rods. The ports on the '84's head are different than your '89's so, not sure if your injection will bolt up or not. Also, I don't think the '84 has a spot for the knock sensor either. To simplify things, you should try to find an '85 or newer motor. Here's some helpful info: http://www.lcengineering.com/technot...97f167802c3221 ------------Hans
Old Jun 20, 2008 | 01:09 PM
Oatmeal's Avatar
Okay, after reading this post: https://www.yotatech.com/forums/f115...n-info-146844/ you should be okay--------Hans
cars-guy
Aug 16, 2020 06:59 AM
okamikai
Apr 30, 2018 10:19 PM
Flossy
Aug 5, 2015 05:14 PM
msane99
Jul 17, 2015 10:13 AM
