more power for the 22re?
Old Jul 5, 2009 | 10:06 AM
M13Utah's Avatar
any one know where to find a turbo or supercharger for the 22 RE motor that is not electricly driven off the battery. also what other modifications should be done if supercharging an engine? i have a high flow intake and thats all right now i don't believe a larger exhaust would add that much power to notice a difference any knowledge on this? Thanks
Old Jul 5, 2009 | 10:15 AM
algranger's Avatar
Tri-y headers will help you out quite a bit.Exhaust on a 22re isnt as important as on a 350 or something, they run almost the same dumping out of the headers as almost anything else. If you want to supercharge it you will need to build the hell out of the bottom end and get a stronger head gasket and probably run oversized valves to make the best of your massive flow
Realistically you wont get much from a 22re in the way of power without dumping rediculous amounts of money into it. You would be better off swapping in a 7mge from a supra or something
Old Jul 6, 2009 | 09:50 PM
deserttoy84's Avatar
find a used garrett t3 turbo. gets some bigger injectors off another vehicle. And to finish it off run a megasquirt management system. With stock 22re compression you can run about 7-8 psi with no problems and get around 200 WHP. all that can be accomplished for about 1k if you find the deals.
If you dont have much money to spend a Cam from engnbldr is best bang for buck. 2 1/4 exhuast is optimal or even 2" if you have a header. You dont want to much flow or else you loose all your torque.
Old Jul 8, 2009 | 03:21 PM
M13Utah's Avatar
thanks for the info but sounds like im going to be stickin with the semis on the utah/wyoming hwys. no big deal.
Old Jul 8, 2009 | 03:30 PM
foot0069's Avatar
Speed costs! How fast do you want to go?
http://www.toyotacatalog.net/M1WebGe...F-31B2996C4B75
montanatruck
Feb 26, 2017 07:07 AM
coleypull15
Nov 3, 2015 07:41 AM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
mlavery85
Jul 12, 2015 10:33 AM
