Missing timing plate!
Hey guys I have an 84 4runner with a 20r in it. I went to adjust my timing today and noticed I do not have a timing plate with the 8, 5, 0 etc.. on it. There is just one line on the top of the oil pump cover there where the timing plate should be. It is not broken off or anything, it's just not there. How do I adjust my timing now?
without the marks or some sort of index to compare against, with what looks like only a 0 mark, you would need an adjustable timing light to dial in the desired advance on, then match the mark on the pulley with 0. that is assuming that mark is 0.
since you aren't even sure the line you see is 0, all I would suggest is set the idle and timing, with the timing matching to that mark, then drive the truck. If it seems sluggish, advance the timing a bit, or if it pings, retard the timing a bit, and don't forget to re-adjust the idle when you change the timing. Keep adjusting things till you get the highest advance you can get without pinging at light throttle in a higher gear like 3rd or 4th, and without pinging at high RPM's in lower gears.
I bought a timing chain kit with cover on e-bay a couple of months ago and the timing tab was barely legible. For the price I paid, I guess I cant complain. Yours may have been replaces with a cheap casting from overseas. Get a new cover. 50-60 bucks for a decent one with numbers. Dont buy sight unseen though.
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
