Lifting 85 Pick up
Old Mar 30, 2007 | 01:53 PM
corvettelvr73's Avatar
Lifting 85 Pick up
I just got a 85 toyota pick up and i want to know the cheapest way to lift the front about 3-4 inchs. Could i just a Add-a-leaf or new leaf pack. I just need some help with this . this is my first Stright axle truck. thanks
Old Mar 30, 2007 | 03:55 PM
85 SA Toy's Avatar
I would defenitly recommend a new leaf pack... I have a 3 inch leaf from downey and I really enjoy the way they ride and wheel... Have been on for a year and a half and no issues to date...
Old Apr 1, 2007 | 06:09 AM
mudtoy's Avatar
springs would be a great way, but rear blocks and front shackles would probably be cheapest. I have a 3" body lift, but it was on before I got it, rather have a suspension lift though for better travel, depends on what you want to use it for the most. You can get rear blocks, u-bolts and shackles for about 50 bucks.
Old Apr 1, 2007 | 06:21 AM
Dr.Trevorkian's Avatar
i'm guessing your 87 was lifted and your taking the rear springs from it, which is why you are only concerned with the front, so why not take your stock rears and put them up front?
Old Apr 1, 2007 | 01:57 PM
Would that work?
Old Apr 1, 2007 | 02:43 PM
Hayes's Avatar
Rears up front is one of the more common ways to lift a rig inexpensively.
Old Apr 1, 2007 | 02:52 PM
bruzer's Avatar
DOsen't that move your axle forward like an inch or something?
Old Apr 1, 2007 | 03:57 PM
Hayes's Avatar
That I do not know.
Old Apr 1, 2007 | 08:07 PM
Using rear leafs how much of lif do you get.
Old Apr 1, 2007 | 10:05 PM
Hayes's Avatar
If I remember correctly this rig has rears in the front and chevy 63" springs in the rear.
Old Apr 2, 2007 | 12:17 PM
How much lift did that give you?
Old Apr 2, 2007 | 05:10 PM
Hayes's Avatar
Not my truck...wish it was, Anyways, he has 35's. Most people with 35's have 4-5 inches.
Old Apr 6, 2007 | 04:33 PM
mudtoy's Avatar
Putting the rear springs in front will move your axle 2" forward, the locater pin is 2" off center than front spings. Gives ya a little more tire clearance for the bigger tires mostly rub on the back lip of the fenderwell. Cheapest would probably shackels up front, but try to angle them @ 45 degrees for most suspension movement. Rear blocks would probably be the best for cheapest.
Old Apr 6, 2007 | 08:54 PM
I thinking of just getting a 3 inch off ebay new. I'm not looking for anything to hardcore.Thanks
Old Apr 8, 2007 | 07:39 AM
socsmm6's Avatar
does it give any lift when you put the rear springs up front? if so, how much?
Old Apr 8, 2007 | 09:07 AM
Sonofmayhem's Avatar
yes, it depends on the spring pack, if you just throw them up front i believe it wont hold the weight of the engine and it will sit stock thats why most people add a leaf from other packs to get the desired lift.
It is a good mod, however requires hysteer. And if a new spring hanger isnt used you may have bad pinion angle, but you can use wedges to ease it.
88sasturbotoy
Jan 30, 2026 01:57 PM
young buck
18
Aug 27, 2018 02:40 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
Backcountry411
Jul 24, 2015 08:06 AM
