knocking rod Questions
Old Sep 22, 2005 | 07:02 PM
RED 85's Avatar
I have a knocking rod is there anyway to make it stop or i should say last longer?
Old Sep 22, 2005 | 08:53 PM
superjoe83's Avatar
thicker oil will band aid it, but eventually it will come out and ruin the block, your better off doing something about it soon
Old Sep 22, 2005 | 08:55 PM
jimbo74's Avatar
replace whatever is making it knock.... most likely, the rod is bent, or the bearing is shot, it could also be a wristpin......
sometimes, horrible timing can also sound lik a rod knock
Old Sep 22, 2005 | 09:35 PM
kyle_22r's Avatar
nothing you can do to make it better. tear the engine down and fix it, or go shopping for a new one when it goes flying out the side of the block.
Old Sep 22, 2005 | 11:17 PM
RED 85's Avatar
Thats what i thought. thanks for the comments.
I will through some heavier oil and try and rebuild the block i have waiting in the garage.
B
Old Sep 23, 2005 | 05:18 AM
Yoda's Avatar
The 85 is easy to drop the oil pan and check/change the rod bearing.
But the knock from our 22RE was from drinking too much water at the local mud pit (bent # 4 rod)
It ran about 1 week more before the rod blew out both sides of the block.
Old Sep 23, 2005 | 04:43 PM
the_4runnin'_beast's Avatar
OUCH!
Old Sep 23, 2005 | 06:49 PM
kyle_22r's Avatar
i wouldn't stick a new bearing in there until you have the crank machined. if it's knocking, it's already too late to slap one in.
bigjstang
Jun 2, 2025 03:56 PM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
cgilley
Jul 25, 2015 10:55 PM
nonstop
Jul 24, 2015 06:29 PM
keithporter83
Jul 18, 2015 12:37 PM
