Just bought a 1985 4Runner
Old Jun 28, 2007 | 10:44 AM
Vanc Island Yota's Avatar
Thanks FnRunner.
Sorry for the noobie questions...what is a "mar-tack"?
I threw it into the search function but it didn't return anything.
I will take your advice on the factory service manual...better then a haynes?
Hey "Locked Stock 84" yes I plan on locking the rear end...any suggestions?
I am just checking the gears in there now...stock was 4.10 but I don't know if a PO has changed anything. I think I want to end up running 4.88 and a locker. I don't need this to be a highway vehicle since I live in a small town and have other vehicles when I need to get out on the highway.
Old Jun 28, 2007 | 03:11 PM
ORS's Avatar
ORS
Martack can be found about 1/2 way down on post #6
http://www.pirate4x4.com/forum/showthread.php?t=459180
There is a lot of other good info there too.
Old Jun 28, 2007 | 03:26 PM
slacker's Avatar
the /85 toyota manual is now avaliable on line .. free down load
i'm sure it's stickied here somewhere.
Old Jun 28, 2007 | 03:37 PM
ORS's Avatar
ORS
I believe you can download it here.
http://www.ncttora.com/fsm/index.html
Old Jun 30, 2007 | 12:25 PM
  #25
Thanks Mike,
I just downloaded...I am sure it will be an asset.
Old Aug 26, 2007 | 08:21 PM
  #26
stirmaster's Avatar
I have a 87 4runner and the driver side rear tire is locked up, I believe it is the drum brakes but have not been successful at pulling the drum housing. Has anyone experienced this as well
Old Aug 27, 2007 | 06:22 PM
  #27
fnrunner's Avatar
you need to back the brake adjuster off throught the inspection cover on the backing plate. if you need more details, search for the factory service manual pdf file & it'll give all the details u need.
after you take the pressure off the shoes the drum should come off fairly easy unless the drum insides are rusty. then you may need the bfh to help em off.
Old Sep 13, 2007 | 03:09 AM
  #28
dkg1869's Avatar
there are bolt holes on the plate for this reason. after adjusting the brake, put two bolts in the holes and wrench down and beat on the plate while doing so.
Old Sep 13, 2007 | 04:40 AM
  #29
4runner Freak's Avatar
If I remember correctly, they will be 8mm bolts. Get 2x 1.5" or longer in case they don't break free. Tighten them together(ie tighten one a little, then the other)
Just my $0.02
Old Sep 3, 2013 | 06:43 PM
  #30
cummo85's Avatar
does anyone know what other toyota models have the same stock rear seats as an 85 4runnner?
ive heard dual cab hilux's and surfs may fit.
ive recently purchased an 85 and the previous owner has removed the rear seats to make storage boxes but now im taking them out because i want more seating capacity.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
HRDC0R19
Jul 5, 2015 06:43 PM
Vargntucson
Jul 4, 2015 12:15 PM
