Jumped into a head gasket job.
Ok so ive been wanting to learn how to do a head gasket job for a while and tonight i just walked over and started tearing my 20r apart. I'm using a Chilton manual as a guide, it says to set the #1 piston to TDC on the compression stroke, how do i know if its on the compression stroke or exhaust stroke? How do i rotate the crankshaft by hand? I'm pretty sure when the groove is lined up with TDC it's at TDC but is there more to it than that, like determing which stoke its on?
Much appreciated
Al
Much appreciated
Al
And on a completely unrelated topic, what's with the obnoxious signature?
FYI: Weather it's on the intake or exhaust stroke won't matter too much. As long as it's on TDC, just make sure you mark which plug the coil is facing. Worst case, you're 180* off, it's a simple task of moving the rotor 180*
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
