IFS Hub Swap Question
Old Dec 25, 2018 | 01:33 AM
yellowtoytruck's Avatar
Hello everyone,
I am starting to tear down my front axle to do gears and lockers and I will be doing IFS hub swap as well to match my wider rear axle housing I put in.
I purchased the Tacoma and 4Runner Brake mounting kit from Front Range Off-road and I have a few questions about the install since it does not come with instructions.
I did search and found some threads on here, pirate4x4 and a few others but they all seemed to be DIY with other brake mounting methods, or the threads were filled with dead links and pictures that would no longer load so I could not get the information I am needing.
Does it go backing plate eliminator gasket, backing plate eliminator, hub seal, then brake mount bracket with bolts and not the studs as shown in the picture.
The first image is one I grabbed off YouTube, the others are from front range's website.
I haven't called Front Range yet simply because it is around the holiday season and they were busy at it was when they were sending me my order. I was hoping to get some help from you guys.
bigyota469
Jan 16, 2012 09:52 AM
Kerby J
Aug 11, 2010 01:24 PM
imanut43
Apr 10, 2009 01:47 PM
jakindle
Jun 9, 2007 10:33 PM
getitdone
Feb 14, 2006 11:45 AM
