how to rebuild a 22re
Old Aug 24, 2006 | 05:11 PM
steelynorm's Avatar
Has anyone ever done a thread or write up on how to rebuild a 22re,
I would love to attempt this but have only looked at a haynes manual.
Norm
Old Aug 24, 2006 | 08:26 PM
Sonofmayhem's Avatar
I found something on google earlier today, ill see if i can find it.
Old Aug 25, 2006 | 04:07 AM
85TurboRunner's Avatar
heres one from offroad.com
Old Aug 25, 2006 | 07:59 AM
thats it
Old Aug 25, 2006 | 08:00 AM
kyle_22r's Avatar
do a little searching, any toyota board should have at least 1 good writeup on rebuilding these engines.
i've rebuilt an early 22R, and a late 22R-E. both are very straightforward, take your time and it shouldn't be very difficult if you've ever turned a wrench before. a digital camera can help a great deal if you're not familiar with toyotas.
also, bag and label your bolts, as they are japanese metric and are hard to find outside of a toyota. most hardware stores sell european style bolts, which have larger heads and in some cases won't work in the same application as the ones from toyota(transmission bellhousing bolts are one example)
Old Sep 1, 2006 | 12:00 PM
dcg9381's Avatar
The motor is pretty straighforward to teardown and rebuild. Find a *good* machine shop that knows what they are doing to advise you on what machine work you need to have done.
For me, as I pull stuff off, I generally zip tie the bolts back into the piece.. IE - front cover, oil pump, etc - that way I know exactly where they go.
I also take photos of each step of the teardown in case I forget, IE:
http://lakebox.dnsalias.com/photos/1...2rte-teardown/
Getting the EFI off and on correctly is harder than rebuilding the motor in my opinion...
Old Jan 13, 2013 | 08:39 AM
nsmith's Avatar
ive got an 86 runner and want to rebuild the 22re. i want any relevant responses. please thanks
Old Jan 13, 2013 | 12:11 PM
Vang530's Avatar
Search.
bigjstang
Jun 2, 2025 03:56 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
coleypull15
Nov 3, 2015 07:41 AM
shisha1999
Sep 21, 2015 08:22 PM
shadowbirdie
Jul 21, 2015 10:38 PM
