how much power?
Old Feb 11, 2012 | 06:18 AM
summit4runner's Avatar
how much power?
Does a stock 88' 22RE have enough power to run four 55 watt aux lights?
Old Feb 11, 2012 | 06:30 AM
James Woods's Avatar
It should, I have just 2 Hella lights on mine and it was fine, if it can't handle the power just upgrade to a GM alternator, you will need it if you ever add a winch or anything anyway.
Old Feb 11, 2012 | 07:36 AM
Thanks! BTW, do you have the GM alternator I'm interested in the part number or a link where to get it.
I guess I could check the battery voltage with a meter while running them.
Old Feb 11, 2012 | 08:28 AM
bob200587's Avatar
I think the stock alternator puts out 60 amps.
Here's a cool calculator to determine watts, amps, or volts given 2 of the units.
http://www.supercircuits.com/resourc...Amps-Converter
Old Feb 11, 2012 | 10:51 AM
EFI85's Avatar
look on trailgears website they have the mounting bracket and a napa number or the alt .
Old Feb 11, 2012 | 11:32 AM
You don't NEED the bracket, there are ways around it
https://www.yotatech.com/forums/f116...r-swap-234812/
https://www.yotatech.com/forums/f2/c...nstall-209649/
https://www.yotatech.com/forums/f131...r-swap-236748/
https://www.yotatech.com/forums/f2/g...-please-71672/
Lots more, just do a search
delmert
Sep 30, 2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
shisha1999
Sep 20, 2015 11:44 AM
agrout
Aug 13, 2015 06:12 PM
Sidherish
Aug 2, 2015 01:42 PM
