How to fill transmission chain link
Old Sep 6, 2024 | 07:54 AM
JaredL's Avatar
1985 4Runner A340H automatic transmission
I am in the midst of changing out the filter and fluid in my 85 4Runner and thought it wise to also drain this little pan between the Transmission and transfer. I understand this is the chain link? I pulled the drain plug and about 1 quart of ATF drained but I don't see a fill plug for this. Do I fill this through the transfer case or when I fill up the transmission, will it fill this too?
Thanks,
JARED
Old Sep 6, 2024 | 12:08 PM
JaredL's Avatar
Just as an edit, I found a nice image of an A340H transmission including transfer case and it does look like the chain drive section gets refilled from the transmission (indicated as a red arrow showing the passage between the transmission and Chain Drive compartment). Can anyone confirm this?
Old Sep 7, 2024 | 05:14 AM
mechkw's Avatar
It will fill when you fill the transmission while running. The drain is there b'cuz of the pan having to bridge the x-member
Old Sep 9, 2024 | 07:07 AM
JaredL's Avatar
Thanks MechKW. In total (not including the transfer case which I didn't drain), 9 quarts of ATF came out: 7 in the transmission and 2 in the Chain Drive link. When I fill it back up, I'll fill 7 quarts, start the Runner in Park then add the final 2 quarts.
Old Sep 9, 2024 | 07:46 AM
mechkw's Avatar
I'd put in about 4 then start it up and continue filling it and checking it
Old Sep 9, 2024 | 07:54 AM
JaredL's Avatar
I'll do that....thanks.
joestox
Feb 26, 2022 11:16 AM
michalik_piotr
May 22, 2007 01:36 PM
scrid
Aug 19, 2006 05:45 PM
kpooch75
9
Dec 28, 2004 05:43 PM
jay-q
Jul 31, 2004 06:51 AM
