Hissing / Rubbing sound after installing rebuilt g52 transmission
Old Oct 7, 2012 | 09:52 AM
maurcs's Avatar
Cool Hissing / Rubbing sound after installing rebuilt g52 transmission
Just installed a rebuilt g52 trans from Marlin Cralwer. Also used their clutch kit. It was my first time doing it so I'm looking for some input if what I'm experiencing is normal break-in process.
There is a hissing sound, or possibly two parts rubbing together, coming from the transmission, clutch/etc., I think. It comes only when accelerating and the vehicle is in gear. I didn't notice it when the truck was cool.
Does that sound like normal break-in on the trans? Any ideas where to start fishing for the answer?
Hoping I don't have to pull it all apart again.
Old Oct 8, 2012 | 02:47 PM
maurcs's Avatar
I've uploaded an audio clip if anyone cares to listen and guess what the sound is. Thanks!
Starting at 17 seconds you can hear the hissing start when I accelerate.
https://dl.dropbox.com/u/10096459/Hi...52%20Trans.mp3
Old Oct 8, 2012 | 05:55 PM
Vang530's Avatar
sounds weird, i have no clue... have you tried calling marlin crawler support and going on their forums? they know their trannys inside and out and are always willing to help with a question.
Old Oct 9, 2012 | 06:18 AM
maurcs's Avatar
I posted to their board, and sent a reply to my original order email. A call is probably the most efficient way to get to the bottom of this... thanks!
Old Oct 11, 2012 | 05:33 AM
maurcs's Avatar
Ok, I'm a dumb dumb. The sound IS also happening in neutral, albeit more subtle. Seems to be related to engine speed.
Other symptoms potentially related: lack of power, small amount of black smoke coming from rear of engine when I would rev the throttle linkage, exhaust/steam coming out of air intake after revving engine.
Keep in mind, the truck has been parked for 9 years until in April when i did a tune up. I was only able to drive it for a small amount of time until the trans went out. Now that the new transmission is in I'm at the beginning of discovering what damage has been done through age and abuse.
Old Oct 11, 2012 | 07:26 PM
maurcs's Avatar
Found the culprit. Replaced this hose with a hole in it. It was easy to find because it had fallen of it had gotten so loose.
Hooked everything back up. Finally felt the power that a rebuilt transmission, new clutch, and a rebuilt carb should bring! It was a fun ride.
Can someone tell me what this part is [PICS]? The bad hose ran from the bottom of it. (I'm still very new and learning as I go)
Attached Thumbnails Hissing / Rubbing sound after installing rebuilt g52 transmission-imag0861.jpg   Hissing / Rubbing sound after installing rebuilt g52 transmission-imag0857.jpg   Hissing / Rubbing sound after installing rebuilt g52 transmission-rubberhosehole.jpg
Old Oct 11, 2012 | 07:33 PM
Vang530's Avatar
EGR Modulator (has a filter in it if I recall correctly..)
Should show in the vacuum hose diagram sticker underneath your hood
mskalmus
May 28, 2017 07:51 AM
BeMiceElf
Oct 10, 2015 09:40 PM
Poncho0206
Jul 10, 2015 06:21 PM
shar
Jul 9, 2015 12:38 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
