help me make a list of tools to buy!
Old Feb 15, 2009 | 09:14 PM
live4soccer7's Avatar
I need to create a good arsenal of tools. I have the sockets, wrenches, screw drivers and the basics, but I'm looking to get some tools that will be good and useful for working on engines (efi and carb). Here's what I have off the top of my head. I am ordering these up in the next few days from somewhere, not sure yet. Any suggestions would be good also.
Feeler gauge (for valve clearance)
Torque Wrench
Timing light
Vacuum gauge
Fuel pressure gauge
RPM Gauge
What size are the sockets for the transmission and diff. fluids? I need some of them too
Old Feb 16, 2009 | 11:33 AM
updated:
Torque Wrench
Timing light
Vacuum gauge
Fuel pressure gauge
RPM Gauge
belt tension gauge
breaker bar
3 LB sledge (have one)
Pulley Puller (good one, lol)
Telescoping magnet
Digital micrometer
Calipers
Digital multimeter (have one)
Hand held collapsable claw (long narrow cabled claw to retrive dropped nuts, bolts or whatever into those areas you can't reach)
Trouble/worklight cordless
split cut wrenches for the different types of sensors
air compressor (what kind of flow ratings do you recommend?)
Z1 boost leak tester with guage
test light (I have a test light)
metric shallow and deepwell 1/4" and 3/8" drive socket sets (have them already)
assortment of ratchets (have them)
open end and box end wrenches (have them)
tubing wrenches
crank puller
die grinder set
impact driver with a set of impact sockets
a very good assortment of screwdrivers, 2 of each type (have them)
rubber mallets in various sizes (have them)
If there's something that should be added let me know
Old Feb 16, 2009 | 01:44 PM
Godzilla's Avatar
Some form of heat/flame can be invaluable.
Old Feb 16, 2009 | 01:53 PM
jessekosten's Avatar
A good paper copy of factory service manuals can save a lot of time.
Cheap trays for keeping parts separated by task, like cookie sheets or muffin trays.
Also have a supply of brake cleaner, penetrating oil, grease, shop rags, gloves and oil containment.
Old Feb 16, 2009 | 02:06 PM
bigt's Avatar
i think they are 22 or 24mm the plugs..
also a 54mm socket for the front axle.
SNAP ring pliers
a big breaker bar
Belize Off Road Team's Avatar
if you have a factory manual it has a list of specialty tools needed. those are the tools i would buy.
Old Feb 16, 2009 | 05:04 PM
jsn_stockard's Avatar
Permanent marker, ziplock bags for bolts, and a full cooler
Old Feb 16, 2009 | 06:40 PM
Brokenstuff's Avatar
Could not agree more..............
Also include a old fashion micrometer with the dial/arm. You can use this to troubleshoot the error codes and quickly check continuity in your wiring/relays and switches.
Old Feb 16, 2009 | 06:46 PM
dropzone's Avatar
Fossilized
engine hoist, engine stand
you can download a manual for the '85 here: http://ncttora.com/fsm/index.html
Old Feb 16, 2009 | 08:33 PM
wyorunner's Avatar
i dont know if people consider them tools and if you have them or not but, jack stands are a must.
Old Feb 17, 2009 | 03:56 AM
88alltrac's Avatar
lots of your preferred brew.
Old Feb 17, 2009 | 07:46 AM
jmazoso's Avatar
A must for any home shop
http://www.irtools.com/IS/product.aspx-en-2916
Old Feb 17, 2009 | 10:55 AM
okie81's Avatar
I bought an infrared temperature gauge (pyrometer) a couple years ago and it's been an invaluable tool for engine and exhaust diagnostics plus it's handy around the house too.
Old Feb 17, 2009 | 11:51 AM
PowellTacoma's Avatar
BFH!
Old Feb 17, 2009 | 12:21 PM
88alltrac's Avatar
Originally Posted by PowellTacoma
BFH!
yes. that and a giant pry bar are my favorite tools.
Old Feb 17, 2009 | 12:25 PM
http://www.harborfreight.com/cpi/cta...emnumber=31383 <--your friend
Old Feb 17, 2009 | 12:30 PM
Dirt Master80's Avatar
tools
A extentable magnet for those droped bolts and a extentable small mirror so you might be able to see why something wont come off before the BFH
Old Feb 17, 2009 | 12:31 PM
91TPU's Avatar
cordless 18v impact gun...my ryobi has been worth its weight in gold.
Old Feb 17, 2009 | 12:44 PM
bigt's Avatar
air compressor and air tools!
Old Feb 17, 2009 | 03:41 PM
skyratcalls's Avatar
JB Weld, ball ping hammer, finishing hammer, framers hammer, beer. I like beer. Maybe a digital multimeter.
