Help!! '85 22RE code 13-Knock Control CPU
Old Oct 22, 2012 | 09:09 PM
ballzer5169's Avatar
Just finished up a rear main seal replacement (pulled tranny/transfer case). Before starting up, i pulled coil wire and check compression on all 4 cylinders. coil wire arked out while checking #3 (4-5 cranks). Compression checked out OK and finally fired up. Check engine light is now on constantly. checked codes and pulled a 13 - Knock Control CPU. Engine seems to run fine but I can't figure out what's wrong or if the coil wire arking out has anything to do with the code 13. Any Help would be awesome.
Old Oct 23, 2012 | 03:44 AM
Crtzlow's Avatar
Has the wire came off the knock sensor? Located above starter, about halfway up the motor and about middleways. Possibly a yellow connector. Not to be confused with the oil pressure sending unit.
Old Oct 23, 2012 | 06:36 AM
I checked the knock sensor and the wire appeared to be fine. I need to check wire and sensor further. The wire has been replaced once by someone other than me over 12 years ago.
montanatruck
Feb 26, 2017 07:07 AM
nonstop
Jul 24, 2015 06:29 PM
jake_v
Jul 22, 2015 03:17 PM
1994toyota
Jul 17, 2015 03:03 AM
mengquis
Jul 13, 2015 10:39 AM
